Eastwood Benchtop Blast Cabinet Item #30721 Assembly
BearsFan315
Portsmouth, VA
7XFp3Co1LL_nFNSZHwhpfQpNyURD4rUV-e1xfSQTejdEr6Ji43glMwpkAJSpZr7uJyG4IEQGBnJU7zL3bUVQQtetoS4CkQTLTir-VRY2mBnH980M83sobA9OqMrR_KYwjnR46b3KJ8rmG9tD1OrxTeVNtnN9VZc03XYLbAobANeCH-yO0dUUXL_F5eqdCog2Dh_i6LxC1Pe_BRhQXJre3n1TzZ_37zvJXmDpfQZTO77VjU7q7Ent_M2BTWpjDSGkFKOxyRDYRp-v_7DoBd6DzImIYW4BDCebPV_uscF_8GPEMdFLDB0KVT-7kHPqueWcaTAKkxDgjpMDYal6j21s7Q82Jge7h6rejOFoE36dgqqPMYslFiKmaCH-3_aaJ-65KOLLPsfpw-8enivnUaLuhn4h8uN2IkZYYqSE_8eGKXoMOBsgX10obAEc1R6ZP_Q_JrKWmCBccXdrWvZtNFUXEDVZuSX6coa3bZBab1V-HfinPMem6qM6tqqHGyoZ_K1eRSy23BdzpN_jlXFt1xxJMsoawh9uy6e4v3NGbbvQxsE_NdzHyaqARY4KbCcu9GWbAeVjmtaG8P0xPLHhgms27XghIJ0iNin8=w1024-h768-no
LEDs Mounted on Front Face next to gloves pointed backwards
spyjP9EopMFyU7VtTfZtJYJx_ZRz6U5hJJktGIrQPwBhd39tYW77fTupJRjzEkyvu_cnpWY-3qZLuqSVldNrnnlyJM749D9Ab3fHF5eWziPgBdGV0xu-sZ9stEGjY6S6yewwfelQawdi2Z6__-EpAnE034o6mdsezShpSNCx-CXY0E852WotA5P0WrrmSQE1bbxpITEZEh9hNCcoWnU-M6gk506eLkMq3DDq667HyADbsNHGB97g4ITcC4PN2uyIlntV6iKUnlxjJDMfnfwDgVq6MugUSJSqOUrEGWV0jmCAEJ1frX4nEWIahV7ubZwLaHk69vrw2mfjChoNnX-32mg0xylreWy3Q_bHNIv3nmfMh7EaDKpz2WAgv5WMq0oxDgVfx9sjm6eihFl07jLYbC39dtmyKpNfd5kXOzkiTBGh6LC5I9il5VgU1QCvZBiKvpgREapWU7POUlyr_AsaWWC8cXsKZyPDpAzGGcnwSvwJDC8KHp6-3fOawUHWpgKjkVbZPATyU5oV1DeHkneSTi9eZRbChEqPG-OMOvPDjX5odQXZN3WFjq59VoZhw-saISNYKymT0HnFsW8HJx53zwbbz3BsgX2g=w1024-h768-no
Lid Open
BearsFan315
Portsmouth, VA
So looks like mounting a set on the Lid pointed Down and maybe a set on the front facing back would light up the cabinet REALLY NICE.
or possibly mounting a set on the lid left & right like above, then another set on the front & back of the lid ALL pointing down.
may have to test this out to see HOW it looks. Needless to say these things are BRIGHT and CLEAR !!
They do get warm, so hoping mounting them on the metal frame will help dissipate heat.
will do some more testing on location BEFORE i fix mount them where they will live !!
NUTTSGT
Northern Central Ohio
Let us know how they work out after you start blasting with them in the cabinet.
BTW, I have my blast cabinet shop vac (2 Gal Cman) vented to the outside.
BearsFan315
Portsmouth, VA
can get the power supplies ALL over eBay and else where, as well as the connectors. i just used my PRIME to get things a lil quicker and local.
Sharpest
South Texas
Thanks for the links. I LOVE Amazon and buy as much as I can from there. I rarely need anything immediately and prefer to avoid stores and the general public as much as possible :willy_nil
BearsFan315
Portsmouth, VA
ok, was asking cause many people are upset cause it is labeled as glass bead but it really crushed glass !!
say it was really dusty and one shot use for the most part.
BearsFan315
Portsmouth, VA
Starting Collecting PVC Fittings and such to build and layout my Blast Media Recovering/ Dust Collection System. I have my Dust Deputy on hand, and plan to hook it up to my 5 Gallon Shop Vac.
Shop Vac Fitting on end of Tube is approx 1.12" dia
Fitting on back of Blast Cabinet it 1.50" dia
Fittings on Dust Deputy are 1.90" dia
BearsFan315
Portsmouth, VA
Granted i bought many fittings, elbows, tees, couplings, reducers, etc... it came down to these parts to make mine how i want it: All From Lowes:
5ft 1.50" Pool Hose
1- 2" to 2" Flex Coupling w/ Clamps
1- 1.50" Sanitary Tee
1- 1.50" 90 deg Street Elbow*
1- 1.50" 45 deg Street Elbow*
1- 1.50" Pipe Plug
1- 1.50" to .50" Bushing
1- 1.50" Rubber Pipe Cap
6" 1.50" sch 40 PVC pipe
SyQ167F7On5Ylw_RMzGJ-gVxVojrKte2L-af6Z5q086Q_t89JRfmqWKOsWLOhPEyRLuCnvn4zndlaP75gnIDlWgNnmlnF4nodoncbHCf8sloylcc_yUOV4VXbwc6QA50aaL_0DicvrFt7mPvZdRGwQZgNyZhj3kccBwftOwtdSEbYgQAYZrrQQEj_irS9ql5ehnQZuwnVPp4_1e8cvVQpeorb62004aGP9JETyP45lmDu14X7BJwcfHF5lruoCD9vWRABmKM_eoGOsvZn-UlI84XGHkLXu8aNFHcNd2WiP8reichGLwvNQaerp9jJFiYIG77Wnt4h99BxZUK2vdwOFCe4fUOt5c6emG_MqWpVIPo30PmMFDVVLWAtoGHIFgqLcONSVHzmyvuax1VPod6SwKitW-kCqd-sp1wW-TtK_1ywriXgckQ_DZlE_IJxjODTe7nstindlo6O_lvHP3iJcIGa8K0fmX6IaLEQ6QGY6yIIFpwhCwyU34cWj2fax63gf3Tqa_1G7ZnJ5V8t5EfpqendTR459yFj7QDpFOxdJUkG9-WlkV0L6iB5F7GU8rTyYneTLoIYyXV0Ri8L-vgR9cOWWSJeJ1l=w448-h332-no
JNFyH3LyYQpTS8U8QWj5cW2fHIfdzgWgfeHtPrAbfUFB6HcOC8eJVI0ucCy6P6Lwzbsnvw0saIDK26bvEGESuHthyeyf_GDC2b9CkY4Ke86_4fbFhnhu0KdDXBr1oBgqgfM5IyZBm42Xr1Xa96CkHkwQ-pRAZbjrpCWFQahTmsUQVw1f-OIIdETqtQaNqX4-hQ8qeKMaf1wc4QNSjVFKOCFj_BgvR98cId4iQysu3egrT47L5hN5OXK8ZxKRbwDKGp0VK-p7MeO-cqS4wJVlQ-fM4t9rCKUoEYjBKfLqwOEz50g8wxxGh8FDyJK9WVvE5bRNM64beaic4FZPSjdB_wwr-mpFerZD1sStvUtzJKyFK7per2hB0d0kjt9YykzeKPB9lsiFjwW5n7j_qzNmzhqI1MYdgh3Q52mhbOkJoHXZQDg4mGTVce7W-D8ZyhjWn5QcFhpvf8tJqXDOeK4W1x4kBEChIujesUW1NDytktfXc0GezAXbS3H9ycG2xc2tFowMRYzAsV-lyr_PHLZ11ZHkI5_mGPdwtocErbRRrO4rsMGQwQlN8VqhIov6ukEUrPgA2N7esDRwYWruYF3aAV8SFHpkkdlL=w640-h853-no
BearsFan315
Portsmouth, VA
Hooked the Flex Coupling onto the end of the Pool Hose, used hte 2 clamps to snug it on and ensure it would NOT slip out. the other side of the Coupling will connect to the Dust Deputy Side Port
8j-2L0S8vODdNgCt-4Qm5NmC0aTI0WBqohOpmw2gZbPXVa_dQbm6eyonlJGdXx5cBYlBK1ZzLoW6DiQJM9vqTnfv6AoUIXmQOWFTAbKbbGw9DB4L-Pvp3e21ePlIuQh3XhmVPNwmHW3PcTxePWbxHaNe5dWAHwLUd-oSscAaEmyjQ-JiploiS5bgD95zF0npqMS5FePMV_33L3UySsRw6GBnCpWJXti2VeImXVvv_tAdWMoFB0iioy7K4Ff9S6tEf2jUxwhNy8W-gvtGdOcifQ469nALFXe3AIgBa3E3kaUX8slYPqAcqXv_mCpnJLkhkGbICNqjJV0ejO-dIYinBCBCQzo5S3BnpQ8dk7Llqjok_a0BAzybNcn1iaQluyRwd2A1l2_TXhUHZ6Br5iy2F9PI0EqKYf-xN69YspQZTWBNVXA7Z3Z1KxqFbnbFJl71y1MmA48dnZ-VuvVXIAHevUIO0NLORN27B1Ih79GE0i46IQMepoWNdet5eodPmGVtc-xQxxEDPbBrhABVhN_mlCs3Fx0noC20DDBzhlzde28EbAaHKo7QPJq9K5WkGezbKVpPA_G501ftzUqCo8r7pokiGxitOJhW=w1024-h768-no
ozhS3DBVTSkdd5zN_uTxGL7VEl9Vlrv2D5iEMFBXudaTmVlkQmtdmAaTJ1TJMw7-S9SvbsxcjktSC-V5WUM2nuIClOjEf_13WsMBH0zcY3sn0n02bpu56h9ragyuPQX6HJM8g_8WxNqHsns0TwjKz3W_1xMW-ugvBjsAce6myW8HQxE4pf2SJGEURKRG9-vBsvgUQDwCwqLUgd3Acxl4-fZa5N9dCtQaTNHqVwh4hV6DIGPsQkMAbXzrVXiIn06eTjPjOZmgSUQwVdnyaaZKVTNLPQaofblF1VP_w0N5FnpDeSOrgchtUXnzVKUPjCuB_Z0wE-M2VgG5vNpAJx08h9xvytjHlD-Z3obB3CWKBDcEnwPPAm8FWIRYibPUX-qNf9fjBnEewY3JcCjha9vANq2IUpFmijGMgPkdWN7IiMXVmpSDAMYaFx3MZgYxllL1BcSGjjs41ZM_OuPK_dgNDkYJOlyWaue-PE3WdbomhK441G1uESD_uft2c3BQxnlNbJGm7hQz2xpReR7PnClGOifgdCPXQzUM1FoTPdiE0N8e-oR45lY4wqtjOnQyctRVjYzHa44RQ55eKc-nac26j8Ksc-n2Cpor=w640-h853-no
BearsFan315
Portsmouth, VA
I then cut a piece of 1.50" sch 40 PVC to about 4 inches long.
Then took the Rubber Cap and took a hole saw and cut out a 1.12" hole in the center, or roughly center. This is for the Shop vac hose, since the end is about 1.12" and tapers up to 1.25" i wanted to ensure and easy slip fit that was air tight.
HIeYCj8QObmhDi23BUdeurlyHDMEBGMPCAIzkW5DX_TGRZrO8FCcV4m4GAAyUnUCq6H_ByY_juXr85xnIdH9MkEMDpOm7b4d_hBRdt2OmxCADIfAdTVNrGdYrVWxYdR9SCWYoaD_Dqi0gpT2kbPielwQ8shVVegRMo-ewv78CSKWnlzr3xcx7a2T5klE9l_HNtUeL1361LQGB1ITkw8PAmJHOcn0-It44dDph40UUOwzuYyOFIK1EWFDoQcykPPxV8xdCf2KUi3lOtpQx2wCyziek108b-vEHhnK6OVJDNjd9f-6qpBp9W4OzP4SXowpuAkxxlhwPmagux0jfSst-TaD0NW_M3uXbcEGX7kggDIcdfDX1IfaNoZjjIOGnAZ_OFVUroT4j6bQg6lCCHtIjINbf92OXOu6Rv0jA5sljam9EX9sRtaKvRiLqTycYwQIQwx1TjwXy-FV93DdabgmP6PG8cN20kC9XqpWpevnXonZUv7k2RB4AaS_JRVHPAHJzfb_pwbyB_L8bd4f0AbAklN0BJI-epmaYwIM_aam_T0kDUjkAZsSJRhCkFZLZI5gg2mpTD_dv0Dnn8YuRsJVTXCwY_i0HRWj=w594-h587-no
BearsFan315
Portsmouth, VA
after various testing, i came up with my solution for connections and fittings.
Sanitary Tee on the Inlet of the Dust Deputy, direction flowing towards vacuum, since this is the flow of the air naturally. then on the vacuum end, i put either the 45 or 90 elbow depending on where and how you want the exit angle. then put in the 4" piece of cut 1.50" PVC pipe, and the modified flex cap.
you can swivel the elbow get the desired angle add more, remove them, etc.. you can connect direct to the tee or dust deputy if so desired. i plan to mount mine on a shelf UNDER my Cabinet, maybe on a rolling cart ??
AleRD1mhiiVDNWhQs7j9qNn4r53zt_YUzTvTA3th5zgfwYlXBqstLYH9eQKw06B2MXs1e1dy_aUW89lIIjxMUOyPHOs83JMer1ACAC3fS7Hifxv2X_ZYxBc_tDJf13GjNdGfuX6iuEZtBGBo8hAHoxZ5HCuOrWK1Kj5xJAoS1UkLIzpjYGOn6gwRAbMkGex1oc3gvr_91MbSArDafmMvmQXeEiyL-AnM_ccH6vorP4tooCkdmGGVz99XGAPaV3JDdGGd_g3bQ5xV-33V9dIBfvnXyu-bncM5BAbr3fS9x8dLfZwFAsrzxAVgm2lbfp12nlzsr9zjjSMOAM1BtyN2RYVW-vOgk1I7_wQnu8hk6EwdI8MYc54Zsci6LmdTxSsrP8Ot21crzT_GxeWWGstw3HZ_5iM5GMjHBZ0mD1pK91fAQe9wHCZB30OACuQr5MFzbdc4IgRaFkFs5r3oJfk0aDieYsM-sCIwZeRhTIS6UvWeRGKqXBPMVqTpQeXD3q09GEWiG9ttYE7wZiKMo2NtGhnXDJIfVPDa50OXw4cGIixMm4u-vl0Dpm7af9CGaQ-NS0xwFBZH1CLhB4f2Isyjs20psOl02qyq=w935-h536-no
Setup up with the 45deg elbow
tJyRCg1ixpVznaQH3u9UtpqfL4sdLw-XjZDrre5X3cvNh_vkpcQSockKlteIBlKngyYr_MWvYvvvy3TUOT4ZjDl-80B8_R0NvbjnPsmqVzXxm4ecQvDzLtd1YQ09sLLkdkLBwBXnv6Npaq6XY8FsH-zfeiIi-wfstCMZKiZic1qcT3VDkhUflZcEJN9T8vGcj7qf4l4spfv4t9s3WWXKtH1AkcN31Bs7jsDwhErbeclf_ZGzn7LoysuEfiuyF_onCi0y1DkT9t2aaPkeXU7tHdS6qdYtHulEDixO4ypcYXKxcl4ke3piKN5egnSdTch3ninzfZ1LB_vkKWPduM723tHmGcT65LjkBkOANe76Uq0gH6BSq863nqT0nw4e-uDcW0Pt8Vxf0oNFkX36ykQue8Cp1iAUgOniHNXGj-r8SIppbZk5uqJ0MiF3fUqgD6P7yYp0GnbvbLXj0rlmLv8NCKMsMC-g3qm3B7iqFSpKdCogk32CwozH6ayTyZ6xhA5t8QruCagYWrWY9W5AkziuOfSUIbOB_hhbHPY8lzNDmVELuWfjgs6U4c-CChJvfD5W7AaiNQxUP9JedAcfRg7ZI6n-e6Cmo05N=w806-h661-no
Setup up with the 90deg elbow
BearsFan315
Portsmouth, VA
Now on the other end of the Tee you can plug it off, or use a reducer, or plug and drill holes as desired. I found out in my testing that if i had it plugged then there was TOO MUCH Vacuum and it would such in the Plexi Glass viewing window !! so i tried to reduce the suction in the cabinet. I tried drilling a few holes in the 4" pvc to reduce suction, this worked a little but not enough to stop sucking in the window. i find that using the 1.50 to .50 reducer works great. i can also tape over portion of it to reduce air and increase suction IF needed.
3RY2uLpj8ohgpcTTtsK_xD6P4u2fsvsu9-4CijBNHKoLti86tCNfMO0YXwYpW2SdU5tw4yDJvJ1kzzRHIgz_EajiiQWHnf0FN0eqUFhnw2rWeLc230vJ4RLM5cOCiGVu2puATLwMY9kjfZMx_pkocyI94hef9i9aPeb704ihJNO9x1oZqDzsTu3yBcAeyJkgUHrKxFvhZOORSkM4uWEpHYGSaBH6XFrkne_75qvxo-rKlDY1WkCPjxfr3Hu4lYFWitUw_djGB_s4nAqWaQjYARUDevYHUDLQJa0ZPvpgB1uBgTtzRGjAUFptAw3RxXQireJ0Hof_OmbPpE3XKC9UXl-FaBwok5HALVCjxTHC2URCHI_-IA29EFUjpPDVF_OvUMz3UjX5lmXhU86P4c9VFXLsv8SabFsf1b9_1sty4iL1rFMKtEq_Pt0yY3Vt6Sgad9jivs6t3KNFv8YXfpc0vTh93zhz-s5hf6TvPbE_4cd1yiNiL9pv5Qty2Ks_bqp6uowQuu9d2gQj7_1EUDPuog8hK7icXDoq32QH3_IEzkXlSf3ObAvKOF43xpo2gL2-fFLDChJpeOo_914Q_OJuAZZtzLnIQBpq=w860-h460-no
Reducer & Plug
XG2UkFRjT9JMN0jdHDMNSIBpd7XJ-_rgmXSh4_fsK1K7CvG6lZBdIk2q67sUBodyTieWhzS_AJv6J45F1BxBGTLEFvAoxn8_LxtCW0uYKOAF814mkbjghgNCOwQPlbQoXdYyrBI_SvqD8W4mQSAzJD2dkn2EGiN2MJjJPlDLTjaIdLY1NoGveuW_mBwtm7tJ8W9kfRwMZLJ7GAsOxYrslBgd91XyswdkuJi6w_Sb0f8G-wfLX_n9Mjw-wj7j5NOpohesnnwiOL9mg5lJwrhfeTWPuLqzzWX7n3cPFEVsORG3PtGvJItghH6Md-OSU7WGiaNserPQENsRfeJoztX1RuocSh10h1564Sug2MKAY0oOMqGWsYAbb7-7PXZEI_zyAlPGx0vO0VU7GnFzo4eG-YZ0oAXynlbYDL_awqUM0HlHx2EqeZZ_Ejh2PQOd0Ji3d--k64ICwIm_FsLy2xVyRUt69FtYq9_PHDHwwH5HXA0xSniJjbOBcDIb6u8D2bSVU9aptlan3xyfnDgRHBChahprQOV29Qup4ksnWvWvkKvuuDRiwdgv9G66zj-KSQcpzbsJDPafC5nhy9TglWB_U7OIFc4i7SWj=w261-h348-no
BearsFan315
Portsmouth, VA
Yeah I Know this is a pretty primitive set up but it works, I know have to build by bucket for the Deputy. Simple yet effective, most expensive plumbing part was the hose. if you have spare laying around it should be cheaper.
ready to get this into the test mode. and actually blast something ! looking to get 80-100 grit glass bead to do my general blasting
BearsFan315
Portsmouth, VA
Got in my clips, and they are nice, use 3M adhesive tape, and stick like glue... hold the wires tight and in place.
X-ePEPMKjtaBmmn5ACIj4VbofgOmxXJkQwQwsmASsVF5Ftdu98mIRPqohhKdQCZJyjHu0VkarOr8gojFDeZ-5rHVtbTpjE7vH8ALTLkuBPHVOrNWZ2TvN5uYUC8ptWtdziTAKdeUaeqRE-T5QQYOqsJJH6zdmZSrJL3LbVeA8rV1Mjbmv9-A3Hy8Rt4rhztqCXiiwBzjD3y-c-uxVdaruUaAysvgoV2TAjAwJzeS3kLrPCGAoOsej_0CxJ2CV-dAZJzVvAKXig_jQV-sOCpLytKxBPOgM8Nb6aicCbO1Rw5dJKkYOSDcUbr7CxFG1Yno5brc8rrL1BJcU_5ebTiTW3kF6Zboe05NNDugcMQzSyt4GCkdUFihvtCDPyArP9oOE_xt3pLiT_8h9q-tglhHzIRKpHxuzeLJoNEfqCIaMwl9kCeyi9lMlPBWX_ZIoZtYDXjrn8pBVCqOvAeA4WDxLqu5AV1aan6LeRcVYtpx5C8ueP7vzj_562XudR_z75sG6UPkB4W62oKc53U2yekCOR820hxaj4cqO7c2fKTHEDbwMIT4KGNMQu7EY-cGb4Lx52Z-kPAp9GDwgygHx4X292OkMprGwi_t7UxX6d8iumhqrfPh095zSw=w1024-h768-no
GSVU0uvtq3orbIvogvE8z1w7dC7ZmvsHKdiThhi16hodN-OVXrgwcS5mDSb95VYJDrEJ32vziznvjfPM4xu1JalY_7Ae9f4ndSKMgZUZHCz_ESKhoB8AoodyKaiNgAyaI7c4TZIpiv9wJMywMJ7dFiIraCR1deTeMVjOYltXCmDZHg2YvlzAjFInQElJQqx7K2kp2zzSAtmRmqFSIrHt72JabGSAcpNHI89lUZpJmQG_511R1lZ3DLyqz-WcxskbqbbB9wukUD8eEUTdlxWJTX-JE-LrIPKQFOS5mYx9wyAFefm7JJjmfZ6ls4Ug4HxmTr6ERQFralREZfQOiy1w-0RdFrx2yHmFhAiw8N55C7JYENUguTdvrniFbfkEz3Yg9Ioweg84oAC2zVhheaYH-e2Gn_Q5FbTQ2NOlU2S1aQqgr23RRhhfGa4sVEnGsSKhPSKIKUqxDlcu49j5xwKcTudr2doCGlfXN8xZ32ILCWHrw8nzLbI9dLJVsB92Z6NhzTUwX1oMxHhcGsBu5aovGilYsEPCcxYKq9J_jBKTNzpJwdtcma68ffMMIbqeI-lKvEscclF4jMQJfmBd6XIkk_TlGhdWlUEF3hmuWPG9IfNJJiBzhOEJYg=w628-h837-no
PtIhjh_0ma5KNctkbcDQrJzbjPctaTURELH7O4XMh0Zk6fb1Lyp6cIwUMWnn4dWRMGod6RjGu6lKXoCgaeBSY-ueiC6RBw6RLpqTH5BGfu2bVMkYKjH_dUjncoOdyvCsW5ESJAb2qrsZ4aKsD7RaH0L68K-hCJ10aevnIGb75yd_T1M58AP6gaNu5Un9V-mnDry0ACuuC-LwFRfZMFwsbus0ubDA3XJl5DNXrJSVtIDFvnZP_-VjxxFpbdFXjI5ZnAmoiJ6uT0ZtQ98q9jF4wbPqUrlf6fvj4GMsIF5GkSB0vgptq2A1xl5AzH_crhrNyz73mfILZCj2LswfkaeAXPHOPgnnNODoy2hHVtLjqiBG9A4z1hKO-OCTVQkLhirk-71UkbqSi6m5BGgUJk9HsemAYXKKvrKaaqA7HXzeawbz8Njt_c7utbXn8zFef0hD4zjIuxGPLUefgBEbt-VIX58DXX3qNY9NlGKkME0JLjlqpy-gIR0kizFYcDSgBnsD75AnUwDCWxAHzLPkf60OkAO-MgqcVXYyVx8PNUrrI9rX8gFKGyYxx7iAGlg8oO8I7TsffmDJM6E19iuOA9dYIIRvvdtTkmpS1SdH5QJd6bCEgQhKyc7mMw=w1024-h768-no
OWjk8bVsgIZVLAS1XGoPcbswyDIMvmXXMuUVNduwy70gluuOeWL85gEGQiBIuYqX2-5DWYcrnIk7bGGfLT3I2KFAvqJzLfMdhZwYyJsBpn9IcSykLAE5am0qzi_NpE-dhl1GR_pQ1dlfRWOWzHhIMb4vvHrLoiNtbMiLt9tyqKwzUsu4Msx3n2Qmp-yL1EBMAlVjZI_xU-Bkp8SKZQBjA9H-vOfbESS7HOynuMAoJSLqOv2lIW08tM7Ihi_Vk_YKGocYGlOAuCVzYW-8gS_pEzHM2_WlwqxhSeb0eCOkE7W2BPHoMTnQQtE0BN2xW4NipyWGQ6INMnmbLMAUB6KkCW94EFla1oeFmht4GHrYaIbUtWic7W5rsBjS76vtZM8_JJGg0Ar7XJOFfAFPSWmsOlEL-0SRBgBVt5SWSJ8IYZnDXvaxTigy3i7QlDzLq_MSerWn4YGYDfYw85tVVxVuymtYBqHkGavuNoF8-A1NJIpeWV_oEAC5n4Xdu1wunxaUkUVO9w7ZZ-d9QvgwAuaCHp8e8gXW_dolbMViDz-lZnm2SM9_I1z6SLerxpr2N7kBNZ2jsDyL09LOPAgN_3kaic0uNXd3eH7KIef1DR66HvRjoAqn3EvwtQ=w1024-h768-no
Tucked the wire up under the rails, and the clips fit nicely !!
BearsFan315
Portsmouth, VA
Ran the machine with 50% Alum Oxide & 50% Glass Bead, 80 Grit
blasted some small brake parts for my 1929
worked great, and no issues. the vacuum and dust deputy worked great. kept the cabinet clean and clear at all times.
2xTyeg8kPagbOPtqtzip4fxBcXU5ltTRwZqmclUHjS331ROstpQbiXcX73oHPpuQw_4T-dIQTehFL57eYHzwc5ZnpmL2XWRKq_ztW85qBWZ8aaApdOYgUoXX7RXKhXZ1KQiwL7g7cuQUI7VPHxTtjw1bAjC7iKhXEaUbQVO2O_iatmmoZcUdQSvgzTURUJO8KTYN34Irus9l7611e8e-fo3fvf1kvN3ioLAKAAbckYr7hvj-WXFfuFQ1yLL0EWHoEGh3tISaybFvJlEW4_sjIi00I7n9qUcrsa52P-qERP1q0AXC7XNvi47xr7Qbf-EJ2hfqNgTgHxTkmMGZmFzBbm4fHkmZ3JN56BcLDPypq8jDOt3br76ppbasLBEbIPiLtodWZ78JrA-SpbnUOdHGPOOMnw0aS_xaype3-s93QnvvLYMelRXJRX2CA-nQVNaienxocIhHmc0RW2H4K-UMQYBevwZnp75Xct0WX-lU1wknU0b7Qx4s2kYO74gA4aeXMM5uKoKuIVr4kgjjI8dZYOsyBriiLMLIpwXH1UM36BlNuzTJpTa_FNl7HD4nvoTdfps8z2_hXvus_mk1mIm-8A2Y577nJy56x14mlR4vDnNVm04saJOIfw=w721-h699-no
