rohartman
Tuned up the C2 and got to use my new to me dwell meter that I bought at an auction.
firworks
IL
I was defeated today in the garage... Roommate's car won't start. Find out the wire between the starter and the pull-in solenoid is broken. This particular car that wire feed out of the casing of the starter and is directly brazed to the brushes... Well I saw a Stephen Cox video a month or two ago about how starters are pretty easy to rebuild and work on and not to be afraid to poke around before replacing the whole thing. I was emboldened. So I remove the starter, take it apart and find out how it's wired inside. I get some new wire, fashion up something I think will work. Flux the hell out of everything because the wires old and it's gonna be impossible to get it to stick. Crank the solder station up, manage to get it soldered. Fed through the casing, put the motor back together. Now I need to remove the nut from the pull in solenoid and feed this wire under it and squeeze it back down. I start to turn the nut to free it and the whole stud snaps off inside the pull-in solenoid. I remove IT from the assembly to see if I can open it up and possibly figure out a way to fix it but it seems like the case doesn't open without destroying it.
So tomorrow we'll be getting a new starter from Advance Auto... :sad: For now I'm gonna go have some beers.
bulletpruf
San Antonio
Some days you're the bug. Other days you're the windshield....
bulletpruf
San Antonio
Did a tire rotation on my VW with my new lift. And I'll tell ya what I needed the air impact to get those damn front lug nuts off. Glad I wasn't on the side of road. That might have been bad.,
A rotation has never been to much fun!
Got to ask about your avatar - what's the back story? Something tells me that the landing was a bit harsh.
glider
Flint Michigan
We're gonna need some details on the 'bird. That's a 68, right? What drivetrain?
Yes a 68 with a 428 motor, 350 auto trans and a 355 gear. I have had it a long time. Been kicking around putting a tremec 5 speed in it or letting it go. The car is just as clean on the underside.
rmalkow2
Brighton, MI
Organization day yesterday with frequent stops to cool off in the house. Hot and humid here and it was a 3 t-shirt day. I took a lot of stored parts and tools to a swap meet last weekend and sold off a bunch of stuff so yesterday was a day to unpack the trailer and wash out empty storage bins. It feels good to get rid of some excess and bring home cash instead.
bulletpruf
San Antonio
Had a blue 68 with a white top when I lived in Hawaii from 2003-2005. Had a 427/4 sp. Damn quick and fun to drive.
Thanks for the details.
Scott
Shed and Garage - Making Neat piles out of messy piles, and putting stuff away properly... Far from done; taking a break. (too hot out there)
wagzilla
Arizona
I hung some new cabinets up, thanks to someone flipping a house I GOT THE OLD ONES
you can see the mess
I made a bigger mess
starting to look better
I have some more work to do but I like it so far
James
firworks
IL
I finished it up today with the new starter. It took probably less than 10 minutes from start to fire. If there's one thing and only one thing going for the Mercury Sable / Ford Taurus shitmobile. The starter is in a relatively easy to service location!
Still a bummer about my attempted rebuild but what are you gonna do. Also if my roommate continues living here much longer I'll probably have replaced every component on that stupid thing.
BonzoHansen
Two weeks ago i picked up a 42" craftsman riding tractor for $100 off a Facebook yard sale site because it had a steering issue. $70 later it has a new drag link plus new mower parts so the blades disengage properly, and the oil & filter is changed. Boom, works great, even has a grass catcher.
So today I snagged one for free because it needs a battery and cables - someone cut the battery out. I'll get a closer look this weekend. I hope to keep the costs <$100 and then flip it for $250 or so. Camaro parts don't buy themselves. lol
Yardsale sites are great, just got to be lucky with timing.
Worked on the freebie today. Freed up the frozen brake so it rolls. Put new ends on the battery cables. Cleaned the fuel tank out and put new fuel hoses in. It has a carb issue but got the needle loose and she started right up and the blades engaged. But no trans movement. Got too hot so i'll get back to it during the week.
PhantomEB
Medicine Hat, AB, Canuckistan
Moving tool boxes around to see where I want them before I build cabinets....
<a href="http://s4.photobucket.com/user/Bronco351/media/image_7.png.html" target="_blank"><img src="http://i4.photobucket.com/albums/y103/Bronco351/image_7.png" border="0" alt=" photo image_7.png"/></a>
I am leaning to the second version but with big box being slid down the wall some more as to leave more room around the corner of the projects and a built in wooden bench being made to go to the right of the man door, will incorporate my beer fridge.
Unless you plan to do something else with the vise, I'd do #2 but rotate the craftsman 90 so the vise is accessible, (and not making a mess next to the door...)
Mr. Roboto
New Hampshire
Mr. Roboto! Where did you get those base cabinets with the drawers? What size are they? And what did you use for the top? Thanks
Check out my build thread in my signature, I custom built the workbench. I have pics throughout the construction.
what kind of bike is that? looks pretty nice.
Thanks! It's a 2016 Giant Trance 2 27.5"
It's been a long time coming for me, I was still on a 26" hard tail up until this.
steve308
Changed the oil on the family fleet. 97 degrees outside - 71 in the garage --- Love the AC.
rohartman
What's a C2? Second generation Corvette?
Correct, 1967 Corvette and it's been in the family since 1967!
Today I finished up the corner weights on the 991 Cup car getting it ready for the Mid-Ohio race this weekend. Changed out the Spark plug called up and ordered them, they showed up and the bill was $900.42, $150.07/ea.:shocking: come on they're NGK plugs they can't cost that much! I know I know we are paying for those 2 tractor trailers that show up to each race to supports us along with 8 Porsche employees.
amalik
Got a pic of the racer?
Sent from my LGMS428 using Tapatalk
LS6 Tommy
Northern NJ
Whaaa??! That's more than what it used to cost including labor to have spark plugs CHANGED on early 911 turbos. The engine had to be dropped to do it... :shocking:
Tommy
Bob Heine
Boca Raton, Florida
PhantomEB, the second version looks better to me because the step isn't behind you when you open the drawers on the tool chest, The bench next to the door is also a great idea. When your arms are full and you need to open the man door, it's handy to have a place to set one armful down.
We went to Costco to "burn" a nearly expired "rewards" coupon, and I wound up picking up 6 of the Feit LED Shop lights. 3 down, 3 to go in the garage, and OMG what a difference! Highly recommended!
BTW Costco has them marked down to $23 and change; limit 10.
PhantomEB
Exactly and I plan to shorten up that step as well probably make the bench a little less deeper so I got a straight line across the front of the garage. Fab table easily movable if I need more table space and if even more needed?? I will have a half sheet of 3/4" plywood countersunk stuck away in the corner.
Aiming for practicality and versatility in this one.
polexican23
burbs-Illinois
not in my garage but about my garage. I cried tears of joy (garage started) then tears of frustration.
My contractor showed up today, unannounced and started site prep. Um, yeah we weren't ready for about 2 weeks. Interested to see what is going on over there after I leave work and why.
Jimmy_B
Removed and cleaned the wheels and tires. Went to see BIL to have the new tires mounted and balanced. Cleaned the wheels again and installed back on car. The wife's happy now.
rohartman
Tommy
You don't have to drop the engine on a 991. I truly believe that's how they cover the cost of the track side support. I did fine the plug for a 1/3 the cost but it's in Japan! but even with shipping it's cheaper, now I know.
That's a sharp looking car & tool box .
Thank you, ya the Tool box is one of my favorite tools I every bought. I call it the war wagon.
boomer12831
northern New York
Thats the one I saw in St Pete that I wanted but would have to build a bigger garage. Will you be at the Glen on Labor day?
