saw blade for trex composite decking
pmalavolti
central illinois
does anyone have eperience on cutting trex decking board w/ a blade other than the freud recomended blade. i feel it is just a gimmick that freud and trex are putting out there but want to see if anyone else has done it with a different blade. i am going to replace the blades in my circular saw, table saw and compound miter saw for the project. $125 for just the blades. money well spent if it prevent killing a board, but i can do the same with blades harbor freight blades, i would love to be able to.
mechanical turk
Monterey Bay
I'd think it's something to do with the tooth hook angle. I know the 80 tooth Diablo blade for wood has a positive angle and the one for metal and plastic has a negative angle. If Trex is PVC then it probably isn't too different from the nonferrous metal/plastic blades.
Empty Pockets
Rural New York
I used a high tooth blade from the local lumber yard in both the circular saw and table saw. I had a high tooth Oldham blade in the mitre saw, they all did good. Just don't try to set any speed records cutting that stuff.
They blades were all sent out to sharpen when the project was done
ryan20021982
Northern IL
I would never use HF blades on trex decking, and I am in no way one of the HF haters. Just hate to see that expensive decking chewed up because you wanted to save on the blade.
rlitman
Long Island
The negative angle will be especially helpful in a chop saw, where a positive angle causes lift and tearout.
Table saws on the other hand like a positive rake angle (though plastics, not so much).
