I recently purchased a home and it has a second garage! It has a 60amp sub-panel with just a few 110 breakers at the moment and plenty of room to add...
I need to add a 220v outlet just a few feet away for my air compressor and wondering what the best/correct way is to do that.
Walls and ceiling are finished and I would like to keep them that way, they were sprayed with texture that I doubt I would be able to match up so cutting out the sheet rock is the very last option!
What I am thinking is feed the wire up the wall from the panel into the attic then over a few spaces and back down the wall to where I want the outlet to be. Is this a safe and code to run the wire this way and if so what retro-fit box would I use? All I need is a 15a 220 outlet for my compressor...
