Sears Evolv brand hex bit snapped like a twig
Jacobson
While the wheels were off, I figured I’d break the old rotor set screw free. I put on a 6mm hex bit onto my 3/8" breaker bar, and the hex bit snapped like a twig instantly. Used the stubby hex bit from my new Sunex set.
I've already replaced my Lisle Torx bits with something from Vim. I am now tempted to get another set of hex bits. At least the smaller ones. I have extra-long Hex bits, but they don't feel strong. Are the Sunex stubby hex impacts adequate?
CJM8515
Those screws ya know dont come off all to easy. I usually use one of those smack with a hammer type hand impact drivers.
Wes J
Peoria, IL
Flat head cap screws like to lock themselves.
Take a hammer and punch an whack the head of the screw real hard. That will break the taper loose and you can remove it with a hex key.
T_Roze
Edmonton Alberta
Smack the head of the screw square with a hammer, before you touch it with a socket.
Works almost everytime. Lol.
scooternut
Pittsburgh, PA
FYI, take the entire set with you for exchange as I was told they don't sell or exchange for singles in the Evolv line.
Mine are limited use in a travel box. I broke or twisted the tiny one, 3mm I think.
J
Jacobson
Thanks for the hammer tip. I forgot that they trade them in. I will try to bring it back and switch them for a new set.
Does Evolv also have a lifetime replacement, or just C-man ?
rlitman
Long Island
...Does Evolv also have a lifetime replacement, or just C-man ?
Evolv has a lifetime replacement (unlike the old Sears "Companion" line that did not), but the fine print is different, and not as customer friendly as Craftsman.
JUNK-MAN
PA
Huh, I have a friend that is a pro mechanic and he bought the same set last year and hasn't broke one yet.
WhiffySpark
They round off before they break in my experience. I have 3 sets in my box I loan to people I don't like :lol:
LB-1911
Northwestern Il.
Craftsman Evolv Hand Tools
WARRANTY SERVICE
To obtain the warranty coverage stated below, return a defective product with proof of sale to the retailer from which it was purchased.
CRAFTSMAN EVOLV HAND TOOL LIFETIME LIMITED WARRANTY
For as long as it is used from the date of sale, this Craftsman Evolv hand tool is warranted against defects in material and workmanship.
With proof of sale, a defective product will be replaced free of charge.
This warranty does not cover expendable parts that can wear out from normal use within the warranty period. *
:see
https://www.craftsman.com/customer-care/warranty-information
Evolv 7-pc. Hex Bit Socket Set Metric
Item # 00910058000P Model # 10058
$5.99
http://www.sears.com/craftsman-evolv-7-pc-hex-bit-socket-set/p-00910058000P?intcmp=ken-pdp-buy-cta
rlitman
Long Island
WARRANTY SERVICE
...With proof of sale, a defective product will be replaced free of charge...
Yep. So you need to save your receipt. And then, when you go through a box of 5 year old receipts and find out that they've faded completely to white (as thermally printed receipts do), then what do you do?
Lifetime my ***. That's for the lifetime of the proof of sale. A load of **** if you ask me, but my guess is that if you're all nicey nice with customer service, you'll probably get a replacement regardless.
J
Jacobson
So, my Sunex stubby impact hex sockets are good enough to be my main hex sockets?
d.mcfarland
Western PA
How many hex socket sets do you need? Quit buying cheap **** and posting about how you broke it or hate it or want to upgrade it.
Buy once cry once.
gdocktor3
Connecticut
Any impact tool is good enough to be your main go to and probably preferred, especially Sunex. They are a very reputable tool brand. I have many different sets of Sunex impact tools.
Also, if anyone decides they need/want to buy Evolve tools, it is wise to pay with debit/credit card. Now you will forever have records/receipts for warranty purposes..
nyrapscalion
Reston, VA
6mm and a 3/8" BREAKER BAR...
ok...time to invest in something called penetrating oil. PB blaster is amazing, don't be smoking when using it
WD 40 is similar. Soak for a day or two, try it again.
Leave the breaker bar in the toolbox.
6mm is tiny, start small and work up.
I like the tap with a hammer idea from CJM8515
In my experience with brake fittings, tighten (a little bit) to 'crack' the fastener free, then gently try the removal.
Soak...soak...soak!
6MocoA
Fairfax, VA
Why all the drama? Evolv is a **** quality line for men without toolboxes trying to put together Ikea furniture under the scornful gaze of their short haired wives.
The point Im trying to make is that if you're the type that needs tools to make a living, you're not going to be buying Evolv line tools anyway. If for some reason you do have them and they break, it wont even by worth your time and effort to go make a warranty claim for a $6 set of hex sockets.
So why get spun up over Evolv 'lifetime warranty'?
6MocoA
Fairfax, VA
Oh and for what its worth, I put a 7mm hex socket (China Craftsman) on a 12in breaker bar last night to break loose a caliper bolt on a Mazda, is that a wrong use of the tool?
gdocktor3
Connecticut
Yea I didn't understand that either? A 6mm hex socket, that is 3/8" drive, on a 3/8" drive breaker bar...:headscrat:headscrat Seems legit to me.
If you take your time and use penetrating lubricant or heat, there should be no problem in doing such.
Take notes OP so this doesn't happen again. Certain things you can't just yank on and expect them to break loose. Especially stuff that goes through a lot of abuse and heating & cooling. Instead invest on items such as: Hammer, punch, reversible impact driver, penetrating lube, torch, etc and keep the Sunex sockets as your go to.
J
Jacobson
I used the stubby impact Sunex 6mm hex bit again today.
Put it on my 1/2" Fuel and it zipped the rotor set screw right off.
Impact is less likely to strip than breaker bar, right?
2000-cvpi
That made me giggle because I know a guy that fits that description.
928'er
Wine Country, CA
The Evolv line is for folks who don't want to spring for Harbor Freight quality tools....
