sberry
Where did the 10 wire come from? But they make that assembly with no switch and a recept
It has a breaker, this is true but it cant be plugged in to 50A service. The cord is too small, it needs to be a number 12.
We built a cooler on a truck. The mechanic used some 16 cord for a couple controls and the unit pulls about 10A or so. I used a 12 cord to it and wanted to use it on welder circuits so we added a couple 20A breakers, to protect the cord ahead from over load but also to cover the smaller control wires and I don't recall what the supply wire was for the unit, I believe 14 @ 20, maybe 30, don't recall but this is similar, we wanted to be able to connect smaller loads and wires to a 50A circuit. We had to add additional protection and a cord capable of short circuit for 50.
From the 50A plug !Where did the 10 wire come from?
How did we come to this conclusion and is this logic for several huge code violations?A cheap azz socket is probably going to fry before a 20a breaker trips anyhow.
At this point OP is probably looking at Milwaukee M18 line.
So plug your power tools into this.
http://www.truevalue.com/product/El...rd-125-Volt-15-Amp/pc/4/c/49/sc/441/66583.uts
OP just wants to run some power tools. This isn't permanent solution.
The original post really didn't include that this was somewhat an idea to work around putting in a recept to a service you actually owned which was a real solution vs at least a good portion of half baked ways to do it.Lol. I was already looking at M18 line.
I got very lucky and found an electrician who was going to be doing work in the area. As such I was able to avoid the driving time charge and the second labor charge.
Ended up with two 20 amp, GFCI protected circuits wired to my pedestal for about 50% more than what the adapters would've cost me.
Interestingly enough he had an arsenal of Milwaukee Fuel 12v and 18v tools. He raved about the full sized reciprocating saw.
The original post really didn't include that this was somewhat an idea to work around putting in a recept to a service you actually owned.
