Can it be fixed..HELP
Luckytattoos
New floor 2 days old HELP
Just had poured ..went horribly wrong can it be fixed not really looking for level now would be happy with smooth though
L
Luckytattoos
2 days old went really bad..just looking for smooth
ssdave
Eastern Oregon
Re: New floor 2 days old HELP
Probably several things that could work. Grind it smoother, or put leveling course on top. What happened? Get injured in the middle of finishing it and had to stop?
L
Luckytattoos
Guy was way over his head ..I take fault to for not really doing proper research and check reference . .but I really just wanted a smooth floor.but asked for a broom finished
NUTTSGT
Northern Central Ohio
The trowel marks are easy to see but is that out off level by a few inches too ?
BTW, moved to the Flooring Section.
L
Luckytattoos
Yes out of level to..but figured I'd live with that ..just would love to get smooth
L
Luckytattoos
Ok thanks was unsure will know next time and kinda freakin about my floor was just looking for any options
L
Luckytattoos
I called him but no response..no I built the garage but paid for concrete.just for this reason
L
Luckytattoos
Ok sorry ..wasn't specified where to post some forums are set up differently.so won't happen again..now we got that straighten out..what's your opinion on the floor
L
Luckytattoos
Supposedly 10yrs experience . .I tale blame for not checking reference , ,just really want fixed
Cave Creek Ray
North Central Arizona
For starters, grinding the floor isn't going to fill in the low spots. And leveling compound, which can handle about an inch and a half per lift, is $35 a bag. You will take 15-20 bags to get that floor level. ($700) Or more. And if you are not careful, you will end up with the same problem. Leveling compound goes hot five to seven minutes after you mix it.
You are looking at $1000-1500 to get that close to normal. Leveling compound is smooth as a baby's **** when it cures. And, you can feather it out using a 4" chip brush around the edges. After all that work, you still wanna put epoxy over it (another $1500-2000 in materials)? You are liable to see every pour of leveling compound if you don't feather the edges carefully...
Another sad example of how a bad (cheap) job ends up costing three times as much in time and expense to get it close to right.
Beginners take note.
Good luck.
InDaRed2
MO
Id make him pay to have it busted up and re-poured by someone reputable. That is a **** job!
I just had my entire 3 car garage floor (new home construction) busted up and re-poured because it had a giant low spot in the middle that let water leak in under the door.
bczygan
DETROIT! Arsenal of Scrappers
What are the measurements of the defects?
Who suggested a broom finish for inside work?
And what kind of dumbkopf would do it, even if requested?
That's evidence of incompetence right there.
Why can't you sue him to have it removed and replaced?
Was this a handshake deal or did you have a contract?
Bill
DalyArcher
British Columbia
wow! That looks ROUGH! How big of a pour was it? How many guys placing and finishing?
I agree with some of the previous posts, a grinder will get the high spots out but won't do much for the low spots. Some self leveling may help with the low spots but feathering it so you will not notice under an epoxy coat will be tough.
I was worried about the opposite with my floor, I wanted level first, smooth secondary. That's tough mate, you gotta work with what you got I suppose and I know it isn't what you want to hear, but may be best to bust er out and try again.
I feel bad for you, that really *****. Of all the parts of my build, pouring my concrete made me the most nervous. Seems if anything can go wrong it will when it comes to concrete.
Flail
Kin folk said, “Californias the place you wanna be
Make lemons out of lemonade. Grind off the high spots. Fill the low spots.
Find a deal on porcelain tile and tile it. You will never get an acceptable finish by grinding, filling and epoxy. Well, I suppose you could but you don't have enuf heartbeats or patience to get that done. Tile would be the quickest option, give you the most durable finish, and would hide that disaster forever. People who look at it would say "wow! Who did that?" Rather "whoa, who the F--- did you?"
TONE
I agree with Flail. I would fix the floor as best I could and then go Race Deck or some sort of tile.
Might not be what you wanted but it might be time to look somewhere else. It's a great space and I think it would look awesome with RaceDeck.
DCarr2
Akron NY
that almost looks like he didnt power trowel it long enough...
my guy wanted to do a broom finish in mine, and then coat it with a sealer. I went with trowel finish and no sealer. I had the trowel finish with no sealer in my old shop and it worked out well, and as far as the sealer goes, its slippery when wet, so thats no good.
Wanna Ride
Screw this. Lawyer up, and get that **** out of there. The floor is something you'll have to **** up forever, unless you fix it now. Twenty years from now, you'll be walking across that jacked-up floor, still cussing yourself that you let it go.
And learn from your mistakes. Don't hire a jackleg to do critical work, and don't pay up front. And for the love of god, don't get a broom finish in a shop or garage. That ****'s for sidewalks and driveways.
James-W
Southeastern Wisconsin
I agree with Flail, grind out the high spots and as best you can, fill in the low spots. In other words, make the whole floor as smooth and level as you can. Then tile the floor with ceramic tile, porcelain tile, or plastic tile. I think you would hard pressed to make epoxy look good in this particular situation.
Zeke
If you can save that please, please detail every step. I've seen bad but never worse. And the fact is that I live with a job like that. Old man that had this house before me tried doing a 20 x 20 himself and got behind. Looks a lot like that does but it's over 50 years old and not worth dicking with. I need to rip it out and place new. But that's far down on the list. If I ever sell, it will become a necessity.
