Impact driver or wrench? If wrench the m12 fuel says 500 in-lbs but the driver says 1200 in lbs you can always get a hex to square socket adapter?
For 1/4 square drive do you really need anything more powerful than the M12 Fuel? I don't. I really like my M12 1/4 square drive impact wrench. It's great for upper engine and trim work.
The new Ridgid Gen5x brushless 1/4 impact driver is very powerful. It puts out 2000 inch lbs, but that converts 166 ft lbs. The Milwaukee m12 1/4 impact wrench only puts out 450 in lbs and the m18 1/4 impact puts out 167 ft lbs. So, I recommended that tool because you can use it as an impact driver or get adapter, 1/4 or 3/8, and use as impact wrench. Plus Ridgid has the lifetime warranty on batteries and tools.
Make sure you register your batteries and have a copy of your receipt otherwise they won't warranty them.
DeWalt makes a good one also. I use my 20v brushless 1/4 hex bit impact all the time. Probably my most used cordless tool. I switch the bits between 1/4 driver and 3/8 driver quite often and has plenty of power to remove/twist off grade 5 5/16 bolts if on the high setting. It is much better than the 18v version
I was pretty surprised today to find mine had overtorqed a Subaru CV axle nut.I have the milwaukee m18 impact driver (the one you can put hex bits into). It works well and is plenty strong for smaller items.
I ran it on full bore figuring I'd still have a half turn with the torque wrench.
For heavy stuff like that, a square is better, as when the adapter breaks in the hex chuck they can be a pain to extract.
I have the 1/2" M18 Milwaukee version with 5.0 red lithium batteries and absolutely LOVE it. So, I guess I will go with the driver and use the adapter. Thanks! Ethan
