Show your new tool arrivals
Skin
Boston
Jet R12 1/4" impact ratchet. Made by Kuani (Taiwan). Nice little piece of kit especially if you like to work fast (700RPM). Sealed head with 2 grease ports is also a nice feature. Its basically a clone of the SP design made faster (and as a result is a bit louder) with a redesigned head so there is no exposed yoke. I think I still prefer my SP one more due to it being kinder on the ears.
Did some testing though and the Kuani definitely packs more torque. Topped it out at ~35 foot pounds. SP topped out at around 25 foot pounds.-14mm bolt.
engineer2
Chicago burbs
I recently bought this Makita cordless leaf blower and am liking it a lot. What used to be a 20 minute chore and dragging a power cord around is now 10 minutes of fun.
04chase
SO CAL
Got these today , prevost high flow couplers. 1/4" thread 3/8" body for two of my flexzilla reels and one 3/8" thread for my flexzilla 1/2" hose reel to run thr big boys . Now finding time to install my air system is key .
That i just got in last week, 100 foot rigid 3/4" rapid air fastpipe . Ill probably run one side for now and order the exact same kit to make a loop and a 1" supply from the tank once i get a good permanent home for the compressor.
Sent from my SM-G930T using Tapatalk
engineer2
Chicago burbs
So you could say you were....blown away?
Definitely. It a Makita XBU02Z. I already have the Makita XLT 18V battery system, so it was an easy choice and was even Direktor of Finance approved. We got a new patio and have a tree over the driveway, so this makes cleaning these up a "breeze".
Wesley B
No where
2135TIMAX from eBay - have to wait until tomorrow morning to see if it works as it should.
anndel
Hawaii, USA
No, mine would generally go on to testing it for a food source.
Mine would smell and test it for food then lie on it and fall asleep. She's not brand particular and wouldn't care if it was Milwaukee, DeWalt or Makita.
RIP Keiko, we miss you very much.
cliftonbros89
Missouri
Picks from the past few weeks
Battery grabber/holder from Napa
Knipex electrical pliers. Very nice.
More Ernst socket rails and another wrench rack
Finally got a DeWalt 18v to 20v adaptor and a few Milwaukee 90 degree grease fitting adaptors.
colin39
Yeah I know what you mean, Hopefully I won't be struggling with Vectra cdti engine injectors ever again! :) They do some other bosch injector adaptors for it aswell!
I did spend £1500 quid on a hydraulic tool for renault traffics, thought id make millions lol. Then reno offered to replace the engines if the injectors seized. However the kit paid for itself and still earns me a pretty penny on the odd occasion.
Dirty Diesels
Nottingham, Nottinghamshire in the East Midlands o
Yeah there some real pricey bits of kits on the market for extracting deep seat injectors, Laser are 1 the most reasonably priced, who makes the hydraulic tool, you mentioned?
Rosso
Scotland, UK
Wee tip for that tool, when trying to get an injector out if it's seized in badly make sure the adapter is fully threaded on after a few blows, i was using mine trying to get a C4 HDI injector out and the adapter loosened off from the repeated hammering. It eventually ripped the thread clean off the end of it.
My fault but just a bit of advice.
willjogervais
Minnesota
my latest.... I have to say, being this is my first knipex tool, I am more than impressed. I can see many dollars being spent to update my pliers drawer. I've always wanted a set of flex ratcheting wrenches, and had made my mind up that I wanted double boxes so I didn't have the redundancy of having more open ended wrenches taking up space. The Tektons flex easier than I had hoped and the torx screw is unable to tighten them so a little disappointed there. But all things considered, they appear to be pretty good.
willjogervais
Minnesota
Finally got a DeWalt 18v to 20v adaptor and a few Milwaukee 90 degree grease fitting adaptors.[/QUOTE]
Do u struggle removing your adapter from your 18v tools? I have to squeeze the hell out of it and it still doesn't remove easily
Dirty Diesels
Ok, advice is always good, cheers! :thumbup:
Wesley B
No where
who are the hex sockets made by?
Revelations
I have a large wiring job coming up. Finally invested in some better electrician grade tools. The jury is out on the power probe solder/torch kit, untill I have time to try it out. The Klein tools are top notch. Even though the Katapults are stamped Taiwan, I doubt I will live long enough to wear them out. The Klien diag cutters are stamped USA.
The Amazon "pocket picker" has struck again..
Klien Hi leverage diag cutters
Klien Katapult wire strippers
Power Probe micro torch kit
REVELATIONS 8
ihateminimumwage
My back ordered 1/4" Williams wrench finally showed up
And the box it was shipped in. All by itself. In classic Snap-on/Williams fashion.
