Corndoggeh
- Joined
- Apr 2, 2016
- Messages
- 1,198
I'm building a circuit for auxillary electric cooling fans for my truck that uses a capillary thermostat to control a relay, however, I wanted to tie said thermostat to only activate the relay when the truck is in the RUN position (the circuit will be open when the car is off or starting). I also wanted to include a manual override for the relay to turn the fans on at any time.
I was wondering if this circuit I drew will be satisfactory or if I should instead use two 10A fuses on each fan or keep the single 20A fuse. I was also wondering it it should be safe enough to tap into the hot lead on the blower since that will be the easiest wire to gain access to that is apart of the original circuit that will open when the car starts or is off. The blower originally has a 30A fuse so I assume it could take that tiny extra load on it.
NOTE: I used an overly simplified ignition and starting diagram on the circuit for simplicity otherwise there would be about 200 other things I would need to add.
