Hydraulic hose fittings
Bellaireroad
Fort Worth
I'm looking at using a hydraulic hose for my compressor whip. The ones I have seen have two male ends. What kind of fitting is used on one end of the hose so it doesn't twist when tightening up the ends ?
thanks
sweetk30
finger lakes area upstate ,ny
you can do adaptors to make swivel .
or have hose made with 1 or both ends swivel .
lots of hydro fittings on the ends are the swivel so this is why regular off the shelf hoses are not swivel.
Rossco
Great White North
My reel has a 1/2 male NPT so a female swivel is required.
Just tighten the male end into the black pipe coupler and align with the reel male.
JohnnyK8
Illinois
I threaded right into the ball valve and used a union at the wall. Tight as a bull frog's *** with zero hissing.
Sent from my Nexus 7 using Tapatalk
Bellaireroad
Fort Worth
I need the fitting in the first pic, between the ****** and hose. You referred to it as a union, is that what it is called? thanks
JohnnyK8
Illinois
Yep "union" check the plumbing section at any hardware store and you're set.
Sent from my SCH-I545 using Tapatalk
slip knot
Texas gulf coast
I used a union too, but there are some hydro fittings that wouldn't need this. IIRC they have different ends and some have swivels to fit up to tapers and such. You just have to see whats available locally.
NUTTSGT
Northern Central Ohio
Just so happens I bought a swivel and hydraulic line today. I was comparing prices between TSC & FFH, so I snapped a picture of the price.
I needed 3/8" but you may need a different size.
