whateg01
I made and have used a hot wire cutter to cut foam stuff for a couple of years now. I've used it sporadically, but it does the job. When I made it, I read several recommendations for using guitar wire and it seems to work, but it also seems very fragile. If I'm cutting fast enough not to burn the foam, it breaks the wire. If I cut slow enough to not put substantial tension on the wire, it burns the foam. There seems to be a very small window where it just works. Does nichrome wire act this way? I am thinking that maybe, since it's meant to get hot, it might not break as easily when heated. THoughts?
Dave
Dave
