Lug crimping tool
kblee27
Singapore
I have this tool for crimping battery cable lugs
https://www.amazon.com/dp/B003X51S00/?tag=atomicindus08-20
The problem is I can't use on a car if I was terminating an existing battery cable, since you need to put it down on a concrete to whack.
I don't want to spend a lot of money on giant crimpers or hydraulic crimpers, since I may need to use it once in a blue moon.
Is there such a tool, similar to the above, but instead of a hammering action, a tool which use something like a screw to force a die to crimp ?
The screw head can be a 3/8" square where you can use a cordless driver or just a T-handle.
Or maybe a portable hand-held vise which can replace the hammer action ?
Thanks in advance.
gungatim
west mich
astroracer
Mid_Michigan
I have one similar to the HF crimper listed above. It works great. I got it off eBay for about half the price of the HF one.
I also modified it with a bolted on plate so I can clamp it to the car or a bench to free up one hand for better control of the cable/fitting to be crimped.
Mark
Alchymist
Central PA
Ditto, same crimper, different label, and cheaper than HF. Mine works fine. Just try the various dies on your terminals and make a list of which ones work best with which terminals.
gte718p
I've build about a dozen electric vehicles. I've built a ton of battery cables. The HF crimper is actually really good. As mentioned, the dies are not marked correctly. Despite what it advertises it can't actually do 2/0 wire unless you modify the dies.
astroracer
Mid_Michigan
Hmmm. Mine does 1/0 just fine... no mods... :)
Mark
FigureItOut
Bentonville AR
Maybe there's a new a batch of the HF one. I had one and the largest die (2/0) crimped 4 AWG, but left little ears. It was secure enough for my project, but not correct by any means. Even still, the crimper itself sure seemed pretty well made. I need to get another one, HF or otherwise, with the right size dies.
Mark in Indiana
Southern Indiana
Good lug crimpers are $$$$$. I've always used vise grips for crimping low current terminals. For high current terminals (forklift batteries & welders), I trust nothing less than soldering the wire in the terminal. Be sure you're in an open area when soldering because of the lead acid battery gases and the solder fumes.
K
kblee27
Singapore
Thanks to all the replies. It seems the HF hydraulic crimper is the way to go.
I'll probably get it off ebay since they shipped to my country.
wayne55
I got one of the crimpers off ebay like the ones pictured above. This may be obvious, but the main thing I learned is that the cable must be a snug fit in the lug to make a good crimp.
mikegt4
sw ohio
A lot of people have had good luck with the HF tool but it really doesn't make the best crimps. The dies are really rebadged metric gauge spec, not SAE spec.
I recently bought a FTZ 94284 crimper to make a new set of 2/0 cables for my diesel tractor and can attest to the fact that it makes beautiful crimps. I am fortunate enough to have a automotive/industrial supplier nearby that carries very high quality lugs of every conceivable configuration at a good price. Well worth the investment.
http://www.kljack.com/default.aspx?page=item+detail&itemcode=ET50116&catlist=260
excellent article on making battery cables.
http://www.pbase.com/mainecruising/battery_cables
rlitman
Long Island
Never heard of SAE spec AWG, but FYI, AWG is defined in metric terms by MCM. We're in a metric world. Gotta learn to live with that.
Fcvapor05
You do realize that AWG and MCM measurements are both based on english units..
redmondjp
Redmond, WA
There is a difference in sizes. The Society of Automotive Engineers (SAE) has been in the business of writing specifications for a century now - I used to work in the automotive industry and we always had one or more sets of the SAE bibliopedia handy. Not everything is metric, even today.
https://www.kayjayco.com/wiretables.htm
Alchymist
Central PA
At $170 they should make nice crimps. Those are something designed for production work, and not a top level set in that environment. Have done a lot of heavy cable termination where good crimps are important, and hydraulic is the way to go. (Think 5 volts dc at 400 amps). That said, the HF & associated crimpers will make a usable crimp if used carefully. And as previously posted, the wire should be a good fit in the lug.
texasprd
San Antonio, TX
Mark
When a crimp leaves "ears" like that, it is not good - you have actually over-crimped. I went through this a few months ago doing battery cables for my Dodge diesel. I tried the Asian-made 20-ton crimpers and got the ears like above. The problem is that the dies are not marked in AWG sizes, but in metric cross-section (I think).
I learned a lot from this http://www.pbase.com/mainecruising/battery_cables&page=2, and wound up buying the FTZ rotary-die crimper he uses.
texasprd
San Antonio, TX
Look on page 1 of that how-to for the first reference to the crimper - FTZ 94284. The best price I found was at kljack.com.
texasprd
San Antonio, TX
Mike, you must have typed a lot faster than me, or had your references to the tutorial and kljack sight more handy than me! LOL
mikegt4
sw ohio
thanks rlitman,
Those were the terms that I was looking for but I couldn't remember them off the top of my head. Must be those pain killers that my Doctor has me on!
texasprd,
I purchased my crimper from them, highly pleased with the tool, the price and the seller. I also have 2 other tractors and some other vehicles to make cables for so I am spreading the cost over a lot of cables which makes the tool purchase more economically viable. I have gotten tired of replacing POS China cables that the big box parts stores sell.
Just tonight my son was talking about using it to put new cable ends on his Dodge truck.
