Help Do I need footers installed
BigBlue1
Sorry this is my first post I have been lurking around for awhile getting great ideas from everyone. I am looking to build a 40X50 bolt together metal building. I am trying to do alot of my work myself to save on cost and say I did it. I am in south Dallas Texas where the ground is black gumbo mud when it rains. I was planing on doing a 6 inch slab with rebar and fiber. I have done a driveway and a sidewalk that turned out really pretty fair. My Question is do I need a concrete footer around the slab the hold the building? I have seen people do a footer and some that have not? I have confused myself with to much data! Could someone please clear it up for me :bounce:
slicktoptt
North Florida
I would say yes, you need to. Would you question a footer for a 2,000 sq ft house? 40x50 is a big building and all the weight is going to be on the edges of the slab. At 6" deep I would be concerned with the slab breaking.
BigBlue1
Thanks, it looks like a job for the pro's then. Thanks for clearing it up.
mikeyr
Santa Barbara, CA
why a pro job ? a footer is just a "vertical" slab that is 1 foot thick and as many feet deep as you need to get beyond frost lines which I assume in your area is not much. If you can pour a slab you can pour a footer.
uhcrandy
Look into a "monolithic pour" slab. Basically its a regular slab with the perimiter thickend and containing the rebar.. Its like a footer and slab in one. Most southern states acept this since there is no chance of freezing. It also depends on the soil.. Ask your building dept..
ddawg16
S. California
Many moons ago when I used to live in Texas....the prefered method was mono slab with tension cables....after they poured the concrete and it had time to cure....(typically 1-2 weeks) a guy would come out and pull the 1' steel cables integrated into the slab until they were under considerable tension......this basically gives you a monolithic slab that should float on top of the soil and take any type if ground movement there is.
Back to your original question....yes, you need footers....that is where a majority of your strength is....without them it would be like having a window without a frame....
To be honest, if you are asking this question, you are most likely in over your head.
ironman2424
i agree with uhcrandy. dig the edges deeper and taper the inside of them. a somewhat triangle shape just wont be exact. that way theres more surface on the bottom than on top. a pyramid shape is strong enough at the edges.
i did this on my 24x32 shop.
