115 Volt DIY Mini Split Heatpump
pwrhockey
Any one tried this unit yet? I have a outlet right where the external unit would go and the possibility of moving in the near future so being able to remove it and bring it with me without another HVAC service fee is a big selling point.
mobiledynamics
Gotham City
You're going to need to evac the refri.
pwrhockey
I emailed the company and they stated that it is a self sealing system and that it would not need to be recharged if disconnected and moved. Just don't know if a system that can plug into a outlet would be able to handle my 20x20 insulated garage.
rlitman
Long Island
It is not clear from what I read if it is a true heat pump or just an A/C with a heat strip !
Yeah, it is, if you run the numbers.
Heating BTU 14000
Heating Watts 1780
14000 BTU works out to 4103W of heat, so it has to be a heat pump to have that much heat output on that little wattage.
pwrhockey
I live in Coastal South Carolina so i'm a little more concerned with its cooling then heating. I have a propane sunflower I can run to bring it up initially on those cold football days but they are few and far between around here. Its a 20x20 insulated garage with insulated door. I'm not in there all that often in the dead of the summer, just once in a while in the evenings having a beverage or two.
Fixin'Stuff
HotterNHellHouston
If you plan to keep the garage fairly cool all the time then a 12K BTU unit should do an OK job in a 400 square foot insulated space. But what it won't be able to do is cool that space quickly if you let the garage, and all the stuff in it, get hot between uses. It may also struggle a bit when you bring in a hot car.
The 12K BTU's is a rating of how many BTU's PER HOUR the unit can move from inside to outside. A garage that has been at 90+ degrees all day is storing a LOT of BTU's in the slab, sheetrock, framing, tools, cars, parts, shelving, etc. Plus, as you're trying to remove all that heat from the garage the heat outside is still working its way into the space. A properly sized a/c system will keep a cool space cool and keep up with the outside heat that is doing its very best to get inside. However, it will struggle mightily to cool an already heated space. It's just the laws of physics and thermodynamics at work. :(
I'm planning to go with an 18K BTU system for my 480 square foot garage. It's a bit oversized, but inverter systems throttle back the compressor to maintain temp so I believe that it will do a fine job at keeping the space comfy most of the time and still be able to ramp up and knock back the hot air introduced when I open the garage door to move things in and out.
