I happen to have 2 consumer home workshop style units, although I only use the newer one. If you where to hook them together, I'm thinking the only advantage would come about if you had them both feeding one larger tank (2 smaller pumps filling the large tank in a reasonable period)? Also, you couldn't actually relize higher working pressure. It's not the same effect as hooking batteries in series Vs. parallel. I'm more asking this than making a statement. Any feedback or comments?
You don't really "need" an additional tank for plumbing. Where the extra tank comes in is either for additional air storage, or as a water trap, or both. As an example, my 5 HP Champions are sitting on 60 gallon tanks without after coolers. If they run for a while the top of the tank will get up to 180F. Air comes out at 125F, goes 25 feet, where it measures 95-100F, and enters an additional 60 gallon tank. The outlet of this tank goes into an air filter/regulator where it measures 82F. I get zero condensation out of my 1 HP air tools that use 30-35 CFM.
In order to get water out of compressed air, it needs to be as cool as possible because hot air holds more water. The other flip side is that higher pressure air holds less water. Its "squeezed out" of the air so to speak and collects in the tank.
You don't get higher working pressure. You get more CFM. Nothing is going to blow up by hooking a two compressors in parallel. This is routinely done in industry.
My system is not perfect, but it met the requirements and limitations. I was leery of starting a 10 HP single phase motor where I am. I was also leery of moving something that weighs 900 pounds. Otherwise, I probably would've sprung for a 10 HP compressor with after cooler.
The Challenge is controlling them.
For instance, do you want them all to come on at the same time? Do you want one to start and then the next 15/30/60 seconds later?
Most pressure switches are adjustable. Some are not. Pretty much all Condor, Furnas, and Square D pressure switches are you going to see are adjustable so you can time them 5 PSI apart on start, with the same shutoff pressure.
