Dave-H
Hi all -
Ok, I got the Coplay insulated door installed and I am impressed so far. The sun beats down on my door (east facing) for 4 hours a day and I can already see how much heat it's blocking from the garage.
But the seal is not great. They installed 'green' hinges which are sprung to put a little bit of pressure against the door, to get it to push slightly against the seal. It seems to work but the seal is crappy.
They left my old vinyl seal on the exterior, and at the very least I want to replace that, but are there any better options?
From what I'm seeing, it might be great to simply replace the vinyl on the exterior, and install a brush seal inside. I have never used a brush seal, though, so I'm not sure if it's a good idea.
Also, I'm not really getting how the brush seal 'seals' since it seems like there are so many tiny gaps for air to get through. Is the idea that the brush has gaps, but it thick enough so that when it's pressed up against the door it will seal?
Anyways, seems like an economical and easy idea, but wondering if it's worthwhile. Any opinions?
thanks!
thanks!
