Welding Table Top Rusting
Coolabah
2nd Floor, 3rd on the Right,Narooma, Australia
There was probably tannic acid in the leather sleeves, which left an acidic residue on the welding table. Should have polished the area with a strong base, such as baking soda/water paste. Then dry and oil it.
Your thoughts make common-sense, sound right if science is true... but it is not... Rust is Iron Oxide. This oxide is reversed by acid ie a reducer, a base is an oxidiser so will PROMOTE further rust ) . My recollection is that the leather traps moisture, and this is what caused the rust. Science 101 , reverse rust with an acid. Don't put a wet rag or leather on the surface. So- as other posters have stated , rinse with an acid. Heck , rub a lemon on it then put a ring on it ...
Whitworth
:rolleyes2
Please don't embarrass yourself further.
Coolabah
:rolleyes2
err... OK . Were my words in English not correct ? Forgive me but it is not my first language. I must say , in any language it is poor sport to ridicule someone in any argument without saying anything intelligent in return. Example: " your mother wears Army boots"... OK then !
But you said that the rust was CAUSED by tannic acid in the leather but it was the sweat/moisture which is why I tried to politely correct your wrongness.... This following is from WIKI ( yeh , I know not necessarily correct...but I thought you might need something easy to follow in case I further embarrass myself with my poor English skills : "Tannic acid is used in the conservation of ferrous (iron based) metal objects to passivate and inhibit corrosion. Tannic acid reacts with the corrosion products to form a more stable compound, thus preventing further corrosion from taking place. After treatment the tannic acid residue is generally left on the object so that if moisture reaches the surface the tannic acid will be rehydrated and prevent or slow any corrosion. Tannic acid treatment for conservation is very effective and widely used but it does have a significant visual effect on the object, turning the corrosion products black and any exposed metal dark blue. It should also be used with care on objects with copper alloy components as the tannic acid can have a slight etching effect on these metals.
Tannic acid is also found in commercially available iron/steel corrosion treatments, such as Hammerite Kurust."
Please lets leave it there I do not want to close this interesting thread just because you are falling all over yourself to stop me embarrassing myself. For the record, I embarrase myself all the time and do not usually care :):lol_hitti
So we can agree for you to still have your opinion that Tannic acid is responsible for the rusted welding table.
Coolabah
Ospho. It will turn the rust black but will be stable for months. Used some on the fender of a car in my **** pole barn 2 years ago and it has yet to re-rust.
Wood bleach or oxalic acid will clean the rust off. Paste wax after
Find a "rust converter" with Phosphoric Acid in it...that product will eat the rust rather than seal over it. A wipe down with lanolin oil will seal it afterwards.
I jitterbug sand mine and then spray it with a muriatic solution. Hose it. Dry it and "wax" it with WD-40. It lasts and keeps it dry.
The WD is for Water Dispersant, named by the inventor(s).
Pointless garage trivia I know-my mind can hold more worthless facts than anyone I know.
Any of these would be my choice
