Caulking slab perimeter
Westbank
I have a ¼” crack all around my garage concrete slab and I have ants and other small insects getting in through this crack. I was wondering what is the best concrete caulk for this ? Sika ?
gregtwojeeps
Ky
Yep, SikaFlex or Basf NP1...limestone in color
deter
Indiana
i prefer to use the self leveling sika. It flows into the crack to help fill it up better
matt_i
SE Michigan
I'd consider putting in some backer rod first if truly 1/4". Otherwise one can eat up a lot of caulk depending on how much the gun is injecting.
gregtwojeeps
Ky
Good points on the backer and the self leveling as Sonolastic / Basf makes it too in 12 and 20 oz caulk tubes. If the slab has sawed control joints or trowel joints, you have to be sure they will not allow the self leveling compound to ooze out on the perimeters.
W
Westbank
Thanks guys ! I will try to figure out how deep is the crack and will see if a backer rod is necessary.
DCarr2
Akron NY
I dunno, I used latex painters caulk along the edges of my floor at $1 a tube (my cost) at sherwin williams, hard to beat lol
