reader2580
I need an impact wrench that remove semi lug nuts. They are supposed to be torqued to between 500 and 600 foot pounds. I tried a 3/4" pneumatic, but I don't have a compressor that can supply enough air even with 1/2" hose and high flow couplers.
Will the Makita XWT07Z 3/4" cordless impact take off these lug nuts since it says it does over 1,200 ft lbs in reverse? Will needing to use a 6" extension on the drive wheels be an issue with reducing the foot pounds to the socket?
I have a 600 ft lb handheld torque wrench to properly torque the lug nuts when I tighten them.
