so, about N years ago (15? 20?) NASA funded some guy in (i believe) chicago who was working on a way to take a ceramic plate, and with suitable magic, move heat from one side to the other.
why? well, as it turns out, NASA funds all kinds of interesting things (i worked on a NASA software contract when i was a "young turk"), but they wanted this for cooling electronics in harsh environments. ya see, most cooling systems need to move something around (gas or fluid) to work. this one didnt, it was solid state. it could be 300 degrees outside, and it would still move the heat from the 125 degree side over.
after funding the work, they bought a bunch, various sizes, for several thousand dollars a square inch, as covered in the contract. NASA was happy, they had solved an "unsolvable" problem for a few hundred thousand dollars, and didnt care about the technology after that. he owned it all outright.
but . . .
so, there he sits. his only customer has bought all he would ever need. there weren't that many other people interested in them,at least for those prices.
so, he did some more work, and figured out that he could build one to lower standards that would only work from about 35 to 125 degrees, and was reversible. if you flipped positive for negative, the heat moved in the other direction. and, he could do it for about 5$ a panel for something that could deal with a container of a small number of cubic feet.
have you bought one of those plug in car coolers like this:
https://www.amazon.com/dp/B007ZYH4BM/?tag=atomicindus08-20
yep, same thing. they add a small fan to keep the transfer pad from getting too hot. some of these units also keep warm food warm, with the flick of a switch. (daddy, how does the thermos bottle know whether to keep the stuff inside hot or cold?)
it might take a few years, but those lasers will be available for a reasonable price. not tomorrow, but not infinitely far in the future, either. i expect they will drop down in levels, to open up new markets without undercutting themselves before they have sucked most of the profit out of each level.
