switch for compressor/drill press
toolmiser
La Crosse, WI
What would you do to make a switch for my drill press and for my air compressor? Both are 1 to 1 1/2 motors that run on a 15 amp circuit 120 volt. I don't like the way the cord arcs when plugging it in, especially if I don't get it in easily. My drill press has a relay that tends to hum when plugged in, plus it's a waste of electricity to have that on all the time.
I was thinking about putting together an electrical box with an outlet and switch, but I remember hearing that most "light" switches won't hold up real long with a larger load like these tools will require, plus start up.
What are your thoughts? Don't want to make a big deal, but prefer to do things once and right.
Thanks for your comments.
csp
Franktown, CO
Your drill press shouldn't be using any electricity when it isn't turned on. Replace the relay.
nehog
Jaffrey, NH
... My drill press has a relay that tends to hum when plugged in, ...
I suspect it is not a relay that is humming, but a transformer in some kind of control circuit that is activating that relay. But if it is a relay that hums all the time--there is something significantly wrong!
rsanter
visalia ca
You can use light switches. Just use the better/higher rated ones.
Been doing it for years with no trouble
Bob
T
toolmiser
La Crosse, WI
I was probably wrong with the terminology, it probably is the transformer. I always thought it was the fluorescent lights until I unplugged the drill press for some reason. It's in my wood shop, and I don't use it a lot, but would prefer not to hear it and waste the electricity. A switch has been on my "to do list" for a long time.
Thanks!
PT Doc
Leviton MS302 is a 30 amp single phase switch good for 5 hp on 240v.
T
toolmiser
La Crosse, WI
After reviewing your suggestions, I remembered I had a nice heavy duty switch that I will use to at least get me one of the two done. Thanks again.
LS6 Tommy
Northern NJ
I don't follow your problem. There is never an arc when plugging something in, only when unplugging it, as the circuit is under load...
Tommy
