Put mine together today and got the area I had planned for it rearranged. I would not have given $450 for it but I don't think it's a bad deal for $200. Worked perfect for what I wanted to do with that area in my shop. Seems plenty sturdy. The stainless on the top is pretty thin but is attached to 1 1/2" of plywood. I would not start beating on something with a 10 lb. hammer on it but I have other benches for that type of work.
My main goal for this bench was to expand my counter space, have a good spot for my dry cut saw, a place to do some light assembly, metalwork, soldering, work on the battery pack and motor for the dragster etc... It was also important to be able to store the charger cart for the dragster, Snap On battery charger, etc.. under the bench.
Here's the area before.
And the area after. I already had a different spot picked out for the blasting cabinet so it moved to a different place in the shop. I think the bench worked out well. I did have to space it up on some 4x4's to get the top to match the height of my welding table. I'm going to get some long bolts and bolt the 4x4's to the legs using the captured nuts for the levelers. All in all I'm happy with the bench.
I wanted make a home for my under hood cart. Perfect spot for it now. I cut an inch off the tube to allow it to fit under the bench.
I moved the tool boxes to make room for the mig welder on the left side of the welding table.
