Mystery Tool Of The Day
t100
U.S. made split ring pliers, no brand showing except a "W"
Skyline
Here's another. It's SP Tools 89200, and is 9.5" long.
Kind of looks like the tools designed to hold tensioning pulleys on some Japanese cars, but in reality, I have no idea what this is for.
Skyline
I'm not sure if these were made by an individual or converted and sold this way by some company. It does not appear that they came this way from Vice Grip. I'm also curious as to the application.
Customized Vice Grips:
Enloe
CLEVELAND, TENNESSEE
Hey Skyline do you go to the flea markets/pawn shops and say "give me anything no one knows what it is"?
Yuo manage to fing some unique stuff
t100
what brand are these? it's a circle around letter "K" with letter "N" on the right, marked as Japan.
Skyline
:bounce:
My son and I buy collections of tools every month or two. The last couple of collections have been large roll cabs with top boxes that were packed with tools. They were owned by long time techs, one recently deceased after 50 yrs in the trade, one retired after closing his own shop of many years. It seems that in every large collection we find a few of these oddball tools. The more experienced the tech, (and the more brands they serviced)...the crazier the stuff.
bgott
Houston, TX.
This thing is flat on the bottom. It kind of looks like a wrench but I don't think that is what it is.
bgott
Houston, TX.
How about this thing. It looks like a mini press or a clamp of some kind. It's 2" wide, the inside of the frame is 2" and the wheel is 1 3/8"
bgott
Houston, TX.
we used to use these in a photolab I worked at the pinch lines **** so you could change pumps and stuff
Thanks! I could use 'em for that underhood. BTW, is that "pinch lines ****" or is it supposed to be " pinch **** lines"?:lol_hitti
wreckercologist
cyber-tool hell
Here's one some of you probably have not seen.
It's made by Burgan Tools, Chicago. Patent applied for.
Skyline
Here another. The use is obvious...it's a 1/4" ratchet. But what I'd like to know is if anyone can ID the thing. It has a VERY unusual design. The driver part can pass through the head, and that's how you switch directions. I have never felt a ratchet like this where you absolutely can not feel the teeth as you turn it...must be a VERY high tooth count; I guess by eliminating the direction change, they accomplished that. BUT, the only markings are R & L. Seems very well made though, handle looks like a Snap-on knock off.
sk farmer
nd
it is a gearless ratchet. it looks as if it may be a titan brand. i think they have some sort of "sprag" clutch rather than teeth
mkdive
NPB (Socal)
I've seen those made by another company . ( can't remember who) But it was at a plumbing supply house used for putting on angle stops. ( some folks call them supply valves )
Here is another example for removing and installing angle stops. The bar, is threaded for the supply hose side (so you can hold the angle stop while tightening the compression nut). :thumbup:
mkdive
NPB (Socal)
whatever it's for, with a little work it would be great for VAG B-Platfrom (A4, A6, Passat.) upper front suspenion links, for separatng the ball joints from the hub housing. :)
If someone guesses what its actually for, I think you will be surprised. I think it's way "over built", but better than a weak tool I guess. :)
