I've been browsing CL for a few months looking for a US made 'old' bench top drill press. Last weekend I found this Atlas 1020 that looked like a winner. My first drill press, but not my first rodeo with good ole USA made tools.
I have decided (for now) it is in good enough shape for a light refresh vs. a full resto. [read: I am not painting it] Seems to be all original and only missing the return spring cover.
I do however have a few questions, primarily regarding lubricant for the re-assembly side of things.
I can't host pics on the work PC, so attachments will have to do. First pictures once I got it home (1 , 2).
Picture 3 - highlighting the grease cup. I understand its function, but am not sure how to go about packing the space between the bearings as shown in picture 3b. The shaft between bearings (picture 4), splined internally, has a hole to let grease in to grease spindle. There was a good bit of grease in here the had become quite dried up, though it was not 'completely packed'.
I would think in order for the grease cup to effectively grease the spindle, the space between the bearings would need to be full in order to force grease through the small holes onto the spindle?
Also, is wheel bearing grease OK? red and tacky? moly EP, etc?
Continuing the topic of grease. Is grease or oil used on the splines of the quill and mating piece (drawing a bank on name)? I plan to use way oil on 'smooth' portion of quill, though the 'gear; portion may require a grease?
Sorry for lengthy post. Thanks in advance for input.
