Rocket1
I have the KTC and the Gearwrench as well as the Snapon YA9350B. The Gearwrench and Snapon sockets will not work with the KTC wrench. The Gearwrench uses a unique spline drive on their sockets and wrench and the Snapon sockets are a smaller drive size than the KTC sockets even though both are regular hex drive sockets. Snapon used to sell socket drive adapters for use with ratcheting wrenches. You put the adapter in the box end of the ratcheting wrench and then you could attach a socket to the adapter, thus making the ratcheting wrench into a ratchet of sorts. The largest of these adapters works with the KTC wrench although it is not a perfect fit. It is loose and the adapter will fall out. A piece of tape on the adapter to make the fit tight should fix that problem though. Then you could use regular sockets with the KTC wrench.
Edit:
I just looked at the 4 sockets the come with the KTC set and one of them is a 3/8" square adapter. So you can use any 3/8" socket with the wrench, although the adapter does not lock into the wrench like the other sockets. The adapter is loose and will fall out of the wrench unless you put a piece of tape on the adapter to make the fit tighter.
Thanks, that's what I wanted to know. Do you know what size the hex is on the KTC tool? Meaning - if I wanted to use the sockets it came with as a low profile option what size wrench would I need to put on the hex end?
