troy-bilt chipper vacuum won't start
section8joe
I've got this chipper/vacuum and it ran ok last year but I can't get it to fire up this year. I'm starting it properly but it will not fire. It doesn't seem to be getting spark. I unhooked the plug grounded it and checked for spark. No luck. I even jammed a test light into the plug wire. No luck. I don't know what model I have and I don't have manual. This plug cap may also be the source of the problem. This looks a little crude.
Untitled by joe Cupp, on Flickr
larry_g
oregon
Is the safety switch for the bag in place making? Is the bag installed and locked properly? This get me right along on mine.
lg
no neat sig line
MFolks
Springfield Mo.
No data plate on the engine or housing? Does the engine have the older style "Point's" ignition? If so,they maybe stuck closed or open.
section8joe
lg
no neat sig line
I don't have the bag attached. Maybe that my problem. I just wanted to make sure it ran so when I need it I can use it. I'll hook up the bag and try again.
larry_g
oregon
If you look you should see the switch that the bag contacts right between the two arms of the spring latch. No bag=No run
lg
no neat sig line
section8joe
Ok I'm still having trouble with this thing. I looked over the area where the bag connects and I see nothing. I did however find a safety switch on the vacuum area of the machine. I plugged it but it still won't start. Here's a photo of the actual machine. Anyone recognize this?
larry_g
oregon
Well I'm of no help as that is a completely different model than the one I have.
Mine;
lg
no neat sig line
Heel2toe
Massachusetts
Since you know you dont have spark chances are you have an issue with the coil. What kind of motor is it? Find the engine model number then source parts from that. Depending on the type of motor the engine code will be found in various places like the valve cover if its an OHV (yours doesnt look to be) engraved in the side of the block engraved in the head etc.
creativecars
Indiana- where horse and buggies still roam
I would first look at repairing or replacing the coil/wire. :thumbup: Coil wire seems a bit short.
Pull off the front cover and disconnect the safety switch wires going into the coil/points area and see if you can get spark then.
