Didn't notice this thread til now. I bought one 2 weeks ago
You know what, I think I mispoke. I think that "rapid pump" thing is just a ratio of pumps to lift height - which is not what I was trying to reference. I was talking about the foot pump which allows you to quickly and easily raise the jack to your lift point without moving the main handle. Then once you make contact you use the main handle as you need the leverage. I'd never seen that feature until I saw my friend's fancy, expensive jack and have been wanting one every since. Now that HF has one like that it'll for sure be my next jack purchase unless something better comes along before I'm ready to buy.
Can you measure the saddle height at it's lowest point? HF lists 3.5" in one place, and 3-3/4 in another. That 1/4" does make a difference for me
Is it a result of the camera angle, or is that saddle not level with the rest of the jack? The line near the 2" mark on the tape, the part that lifts the saddle, looks to be parallel with the axle of the jack. The saddle does not look parallel to that line. Is it?
Snap on decided to underrate the capacity of the jack. I am guessing to cover the proverbial ***. I know that the rep and dealer were asking people to try and pick heavy things, then take a picture and send it to them. I saw tractor trailers up in the air and I lifted part of my big forklift as well as the entire *** end of my F350 dump truck.
This is common in professional lines.
For instance one might find if they were to investigate that our 250DP is a 3ton jack that we advertise as 2.5 ton and test to at least 6 ton during QC and repairs - allegedly.
THE HF jack in those pics looks pretty nice, would be great to hear some reviews. The detailed tech specs posted earlier however clearly show two different jacks (a 2T and a 3T), tho they are also clearly blueprinted off of the same underlying design.![]()
If you look closely at the SO drawing, the crossbar where the ram slides into is merely hidden by the frame, it's the same alright.
Doubtful... Generally manufacturers err at a maximum of 25% above rated load with the safety valve.
It took a lot more than 5000 pounds before the Snap On jack bypassed.
What I am saying is that the daytona and the FJ200 are the same minus the seals/fluid/paint and stickers. The FJ200 was pushed as grossly underrated. I thought the FJ300 was a lot bigger, but apparently it is only a few pounds heavier than the FJ200 and the daytona.
You say the seals are different? How do you know this. Not saying that I know they aren't but how and why do you think they are? It's a seal....I honestly don't see a Chinese company making the same Jack and they make one with one set and another with a different set but yet they still highly advertise the 3 year warranty on the HF
Hiball, as far as I have been told, the FJ's three year warranty is a replacement pump swap. The dealer just does a quick swap and sends the old one back.
Yes, for the most part it's always been a pump swap/repair for Snap on, I know this because I've handled some of the "warranty" repair in the past and kept multiple dealers stocked with fresh units and was paid directly by Snap on.
I'm hoping you do. I was going to ask it someone from Maryland wanted to spring for the snappy and I'll get the Daytona or visa versa. Then head to head one day at my shop.Wait, so you repair jacks?
I am actually thinking about buying one of the daytona jacks and setting it side by side with the FJ200, just for giggles.
How does the Daytona compare to HF's other jack offerings?
Strouty and 90zcar... When overloaded or lifting at an angle do the daytona or fj200 slant or lift a wheel off the ground? Both sound like stout jacks but I care a lot about balance. Which is why I don't care much for lightweight racing style jacks.
I did spend some time at HF yesterday and gave the Jack a visual once over, I thing I didn't like was the lack of valves on top of the Jack. I'm not a big fan of the cartridge type valve, and since there where only 2 valve plugs, I'm wagering one is the safety overload and the other is the high side bypass.... Sigh, this tells me that more than likely Each pump carries a cartridge under it.
