justbarriault
Me and my stepfather wired my shop last week, and thought I'd pick you brains on what we ended up with since I could still tweak it if desired. I put 3 rows of 4' and 8' 2/4 light T5 fixtures down my main shop, (28'x48'x16'), (4) 4' T5's up above my work/tool area (8' height), 4 recessed cans with LED spot light bulbs up in my 2nd floor (a small 28'x12' area for storage and air compressor), 4 outlets in my attic on a switch (lights TBD), 120v outlets every 4' inside, above bench height in the back, and about 2' height in the front section, (3) 220v outlets down each long wall and 1 on the rear wall (seperate circuit for each WALL not each plug), all 220v wiring 6/3, all 120v wiring 12/2 and 12/3, (4) 120v outlets on outside of building with weather tight covers, all 120v inside and outside outlets wired through GFI outlets, conduit run from my 200 amp breaker box to the attic in case of future needs. I have a ceiling fan in the middle of the ceiling, and a small exhaust fan with shutters 2' down in the middle of a side wall. I probably skimped on the breakers a bit, with a 20 amp circuit for each wall (being 48' walls I believe I'm at 10-11 outlets per breaker), but I highly doubt I'll be tripping them
