Tools that save your bacon
dsgreen3
Unadilla NY
I'm interested in specialized tools that you may not use every day, but when you do need them they are the best way to get the job done. They could be anything from roller chain tools to locking extension.
Tony G
NewHampshire
The most recently used was the Time-Sert thread repair kit. We have a fleet of Detroit Diesel DD13's with aluminum oil pans. The drain plug hole is not steel lined and after many oil changes the threads are shot. The use of this kit saves about $1600.00 for a new pan.
ex-x-fire
Sheboygan Falls Wi.
Knipex adjustable wrench. I don't use them to turn nuts & bolts but as a mini-vise. Great for pressing in the pins on brake shoes.
Hagatronics
Melbourne, Victoria, Australia
Nutsert blind rivets. For fixing items to sheet metal is really helpful. On our cheap-arsed race car have mounted a fire extinguisher, window nets, false floors and all sorts of plates and panels.
Got an ebay kit that works great.
Davefr
OR
A handheld impact driver.
It's not used very often, but when it is, it's invaluable and often the tool of last resort.
I would never be without one.
Finky198
North East
12 lbs Slide hammer , 20 ton Hydraulic press , 48pc Rethreader Kit
and just about everything else listed so far...
619DioFan
San Diego , Ca.
Press , master thread repair kit , dremel , 48'' mayhew pry bar , 3/4 inch drive x 40'' long breaker bar. these items have saved me more times than I can count
wafrederick
Holton,Mi
The twist sockets for removing damaged and rounded off nuts and bolts.I used to pound on a smaller socket before getting these for this.
bczygan
DETROIT! Arsenal of Scrappers
The tool that saves my bacon is a George Foreman grill. It cooks from both sides and drains the fat, leaving perfectly crisp bacon.
Now I gotta go get me some....
Bill
Dirtydan69
San Tan Valley, AZ
Oscillating tool . invaluable when needed
In my trade I would have to agree. Especially in doing new trim work next to old. Cutting out old stubborn faucets, changing out door jambs, the list goes on and on. Most places that I used to use a sawzall, full size or mini, I now use my Milwaukee 18v oscillating tool. It's fanfuckingtastic! I never owner a Fein but have used them. I started with the Dremel version then the Bosch cordless, I have two, one in the truck and one in the garage. But once I saw a guy on the job using the Milwaukee I bought one and use that 99% of the time.
davethorik
Norka, Ohio
I have the same Milwaukee 18v, it does come in handy. Just wish blades weren't so damn expensive and lasted longer.
Balor
Florida
This ^ with a 2 lbs sledge has always worked for me weather on a harley or auto. rngr1
Pasha
A palm ratchet is life changing if you're doing any work under a dashboard or super confined area.
MDK22
Philadelphia, PA
Double cut domed carbide burr just a little smaller then major sizes of bolts. ie 1/8, 3/16, 7/16, 11/16. These will cut just about anything and make short work of it as well.
Snap-On SR40k Extractor Set Anything else just doe not work nearly as well. These work on super hard and stainless steel bolts.
Matco 51pc Thread restore kit with 3 thread files Has saved my bacon at least 20-30x
Matco Spindle die set aka die add on to smaller set has saved other peoples bacon 10-15x and me once
13pc Turbo aka (twist) socket set impact Hammer these babys on and if it dont come out it wasnt planning on it without breaking anyway.
Nicholson Mini File Set I can fix small burrs in tight places quick with these and it saves me a lot of time.
High Temp Epoxy Putty For when your co workers accidentally put holes in radiators. Does not contain steel so ya no rust.
Proper Safety Glasses (List of standards you want: ANSI Z87.1 +, MIL-PRF-31013, EN166, 169, 170 & 172, CSA Z94.3-2002) - So many times at this point I can't even count. You want all of that cause without your eyes it will be harder to tune out your wife, watch football, and drink beer.
3m 6700 Full Face Resperator - has saved my lungs after being the go to guy for DPFs also used when doing mold removal with straight or 1:1 bleach.
Craftsman 3lb drilling hammer Small enough to be useful in tight spots and heavy enough to move some metal when need be. I use this a lot at least 2-3x a day on a slow day and over 100x in a bad day(Why the hell would engineers design this like this)
Torch and Mini Torch - Yeah, who doesn't like fire. PS it will cook your bacon too.
Tap & Dies - I have Irwin which have failed me 20-30x times but, good HSS (High Speed Steel) ones are worth the cost and actually do their job. Got no name HSS ones so no clue might have to take a pic and have people help me identify.
jt777
Canada
Magnetic pick up tools with swivel ends. Seems like a small thing but can always find that dropped nut or bolt.
Sent from my SM-G900W8 using Tapatalk
Mgnu
Valley of the Sun, AZ
I really need a good tap and die set that is better than the Chicom **** which breaks tapping a beer can, all without taking out a 2nd mortgage to acquire said set. Anyone got recommendations?
DanInVA
My Sawzall really came through in a pinch today. My neighbor and I were doing ball joints on his car today. The left side would not seperate from the lower control arm no matter how much being beaten with a pickle fork, soaked in penetrating oil, or being sworn at we employed. We ended up cutting the ball stud in half with the recip saw, and using the ball joint press to move it. Sometimes, you just have to do things the hard way.
Sent from my SM-G920V using Tapatalk
FullRaceMerc
SoCal (SGV)
Thread files. I actually used one Friday when one of the guys buggered up threads on a stud sticking out of concrete. It's probably been 2 years since the previous time.
The wise guy response is "My fridge normally saves my bacon".
DodgeMech
what i call "fishing pliers" not used but maybe monthly, but sure as hell are handy when needed
https://www.amazon.com/dp/B000F5JM0O/?tag=atomicindus08-20
i'd use the **** out of them, if i had some...lot easier than busting out the entire tap/die set and rethreading the bolt...gotta do that to a stud for a fuel tank strap tomorrow morning, actually
KWtech90
Flare crowfoot wrenches. 7/8 is an absolute must have for any diesel technician.
