Vapor barrier under 2" foam
brownbagg
vapor barrier goes on top of the foam, always goes against the concrete
Steve in Mi
Mid Michigan
I put the 6 mil polyethylene film under the 1" Dow rigid (blue) foam. If it's a good idea to keep the water out of your concrete floor I figure it is even better to keep that water out of your foam insulation.
matt60j
MICHIGAN
Where did you get your foam and how much is it? Also what is the psi rating? Thanks. -MATT
Steve in Mi
Mid Michigan
I purchased ~200 sheets for my shop build in 82' from the Dow employee stores in Midland and Bay City. It will do no good to tell you the cost, it can't be purchased for that price today and it will only make you cry.
In addition to the foam under the floor I put an inch both inside and outside my block foundation walls and continued the outside 1" upward to encapsulate the entire 2 story building. 2" X 6" stud cavities were filled with R-19 fibreglass.
matt60j
MICHIGAN
I'm crying alright, 70 sheets at $20 a sheet. Employee stores are nice. I work at the old Dow plant in Bay City but I can only get bags candles cleaners etc. -MATT
brownbagg
My argument about the vapor barrier on top of the insulation. The concrete needs to retain its moisture during the curing process, to maintain a lower heat cycle. By having the vapor barrier under the insulation, it created voids in between the panels for the moisture to run too. So the bottom half of the slab dries quicker than the top half. the slab curls. Then it cracks. This is also the same principal of pouring without vapor barrier.
Now contractor love pouring without vapor barrier because they can pour it wetter and the water will wick out the bottom and dry quicker, but the slabs cracks. so now we are at the point, "all slabs crack". No, they don't, only those that are done wrong.
So you in the business of placing concrete, you want to place wet, due to less man power. You don't want vapor barrier because, you don't have the manpower to install it and you have to buy the vapor barrier. You want the concrete to set quick, so you can go home early and stop paying labor. Oh all concrete cracks.
Correct way is to use a vapor barrier on bottom against the concrete, on top of the insulation or rocks. Then after placement wet slab and cover with another vapor barrier for at least seven days. You got to go into the placement, trying not to create cracks.
Engine-Ear
a burnout west of Milwaukee, Wis.
Interesting thread.
"I thought you put the film down, then the foam, then the wire, (pex,) then concrete." -burke65
Me too...Now that I reviewed pics of my own slab, and contrary to brownbagg's point of view, I realize that my concrete guy must have felt that the foam was the vapor barrier, too. Brownbagg, I agree with your logic, BTW.
brownbagg
some foam are designed to be the vapor barrier but the joint must be taped. but not all foam are designed for this purpose
overkill 19
Red Deer, Alberta Canada
My father in law just poured a slab last week, he used a new product that is a vapour barrier and sm foam all in 1. it had a seal adhesive flap for the joints and came in 4 foot wide roll and was some what flexible to form to the contours of the ground. It comes in 3/4 or 1 1/2 probably other sizes too. When I pour mine next year I'm going to use the 1.5 on the edges and 3/4 in the middle. Seamed like a very tough product. I will look up the brand name when I take to him next.
uhcrandy
Just a quick point about pouring concrete too wet. Dont do it! When concrete is strength tested, too much water is not good. For slabs I beleive it would not make a big difference, in commercial it would. Sometimes people misunderstand plasticisers and retardants, for just too wet. Plasticizers make it easier to work and retardants extend working time. Both of these do not signifcantly decrease strength.
