I am contemplating putting a 100 amp sub panel in my attached garage as my main panel is filling up fast. The sub panel would have a circuit for a compressor, a circuit for a 110 welder, a circuit for garage outlets and a circuit for outdoor lighting ect.
The new panel would be on the inside of the garage on the same wall as the main panel which is on the outside of the wall. So the run to the new panel would be maybe 4 feet. I have looked at several wiring diagrams and many call for grounding rods for the sub panel. Do I need those? I thought the first picture may be the diagram to follow for my situation but I am not 100% sure.
ALSO, my main panel only has one bus bar that holds both the neutral and ground wires. Would I run the neutral and Ground wires from this bus bar to the new panel? I also attached a pic of my main panel so you can see what I am referring to. Thanks for any suggestions.
