Unfortunately I dont have one at the moment but its on my wish list.
How are you sharpening now?
IF you can keep a dedicated grinder it works fine, most of us end of grinding other **** and then contaminating the tungsten.
This is the chemsharp I was talking about...
I just sharpen a whole box of tungstens in one sitting and then I have them ready to go.
I honestly don't think the roloc discs have that much to do with it. Most people with little aluminum experience tend to blame the prep and the material more than their technique.
It doesn't matter what you grind your tungsten on. It really doesn't. I usually do mine on the belt sander, but I have been known to use a bench grinder, angle grinder, chemsharp, whatever is handy. What's important is you don't have any base metal on the tungsten to burn off when it gets hot. The shape makes little difference on AC, and whatever contamination that comes from your grinding wheel burns off so quick you won't even notice.
You just need more practice. Most of what I can see from your welds is you dunk your tungsten and could possibly have some shielding issues. The most common issues welding aluminum are heat management and sheilding. Yeah, its important to be clean and have good joint prep, but without good heat management and gas coverage, you're chasing your tail.
Most of the time I do no prep at all. The only prep I do is when the metal has coolant scum or a bunch of dirt or oil. Then I'll wipe it down with lacquer thinner.
These pictures are a good representation of what I'm saying. The tubes are fairly dirty. These are production parts, and getting them done fast is more important than looks.
I only wiped the coolant off the caps from the lathe. The bottom tube is fairly thin wall, like .063". I didn't grind, wire brush, acetone wipe or anything. Just jam em together and weld.
These get powder coated, so getting the "stack of dimes" doesn't matter too much, as you won't really see it. If it was super important the welds not have any sort of contamination, I might give them a quick rub with some scotchbrite or emery cloth first to knock off any crusties.
My tungsten was sharpened on the shop belt sander, and who knows what else was sanded before the electrode.
As you can see, the welds are clean, consistent and have the appropriate bead shape.
I'm not trying to brag, I weld for a living, so they better be good or my customer will be mad. What I'm trying to say is the prep of the base metal and tungsten has far less to do with the end result than most beginners realize. Its all about heat management and gas coverage. I was running a 3/32" ceriated electrode with a #6 cup on a gas lens. Machine is a Syncrowave 350 LX set to 150 amps, balance set to 70% EN.
The welds look good but I invite you to try a red Roloc disk with no Acetone wipe and report back. 150 Amps, 3/32" ceriated on #6 Cup for 0.063 AL sounds steep.
Thanks for the reply.
I think your heat and heat management is all over the place... Aluminum is tough, consistency is a must... I'm no pro but still learning...
you need more power , welding aluminium should be fast and hot,
FASTER THAN THE SPEED OF HEAT
if you understand that you'll weld aluminium
you don't need to clean new stock if it doesn't have oil or some other stuff on it, just weld it .
also, the black stuff is either where you dipped your tungsten in the puddle or the tungsten balled up so badly it blew up (tung too small, amp too high for the tung , wrong selection, too much cleaning balance ... etc)
If I wore you i'd take some community college welding class, you lack basic welding knowledge .
I also think the pedal is more trouble in the begging than anything else, do it like real weldors without a pedalThen you need to know some welding parameters ...
some alu I've done, and a pipe root and cap freehand.
I hate the zirconiated tungsten, it's garbage.
The green (pure) is garbage also, it works only for aluminium and ONLY ON TRANSFORMER machines !!!
You want Lanthanated or Ceriated in available percentages , they will handle more amps and ball at higher amps too, balling is actually melting the tungsten at the tip, if the ball get's too big it will explode and contaminate your work piece .
Never weld with a dipped tungsten ! it's a health hazzard(vaporizing who knows what metals and nasty **** that never occur in nature ) and it will make for a cold(er) weld (will not transfer as much curent ) it's like turning down the amps ~20% or so. Then you get all the problems coming with low amps.
you can feed the filler in the puddle there's no problem if the weld is not stack'o'dimes NO PROBLEM AT ALL !
Also outside corners ... they are not easy I know, instead of cleaning with 7 kinds of abrasives acetone and holy water just take the grinder and dull the corner , take about 3 mm out , it will weld much easier .
Well.. steel is a different animal
I would read weldingweb a few months and also weldingtipsandtricks.com but cold info is just that .
While everyone is posting there welding **** I though I would post mine. I claim the last 1" of my fillet weld is pornographic.![]()
dr_clyde
When you say production, i hope you don't mean pharmaceutical. I did some college work experience at a pharma company and every weld had to be clean inside and out, we had to use a seperate tank to ensure the welds were clean. and those welds while done well need to be cleaner.
Looking way better, I still think you should practice laying beads on flat pieces and then move to your boxes.
Dont be scared to go back over a weld and "pretty" it up if one needs a bit more filler or melted in a bit.
dr_clyde
The problem is your heat input, travel speed, technique, consistency, cleaning, balance, propping, and failure to stop and correct mistakes.Not really the job is done with no scrap.
Besides I did exactly that first. No problems with small pieces on the bench.
Sent from my SM-G900R4 using Tapatalk
Try swapping out the gas lens for a regular collet body and a #5 or #6 cup. I run the biggest tungsten I can get to hold an arc (1/8" for almost everything) and big filler that wont ball up before it gets to the puddle. Run the tungsten up tight in the cup with very little stick out. This keeps the tungsten tucked away and you are less likley to dip it or drag the filler across it.
If you are having a hard time starting the puddle: Start the arc at a nice low amp. Let the cleaning action do its thing for a few seconds. Maybe 5-10 sec. Then push the peddle to the floor and make a puddle. Works especially well on castings and repair work
