Show your new tool arrivals
miguelvldz
Nice set! #goals!!
90zcar
My good friends ford expedition blew through a rusted front brake line and I needed a bubble flare kit to build him a new one. Had him buy me an OTC one off of amazon that had really good reviews.
FOCUS.FREAK
Burr Ridge, IL
I will do that sir. I do work in a medium duty shop (think brown).
The shop usually supplies the 3/4" impacts for us, but I got tired of the politics involving the tools they purchase for the shop, and finally said screw it and bought one.
If it works well, I'll more than likely buy another, just to keep a torque stick and socket on for install, and the other just for removal. (im lazy and don't like beating them off with a hammer every time.)
1/3 the price of snap on, lighter than the snap on, more power than the snap on, and quieter than the snap on (like I said as advertised). Just couldn't see spending close to $1k from snap on for something just to remove and install tires.
Does your shop provide the impacts for you guys?
Our shop supply's us with the ha normal shop tools.
3/4 drive torque wrench
Axle nut sockets 3-4.5in
Seal driver
Tiger tool axle remover
I was always on told all you supply is the general tools. Shop supply's specialty tools. I purchased my own 3/4 drive extension set and 33mm socket. I also have my own 33mm 1/2 drive as well.
NUTTSGT
Northern Central Ohio
I picked up a few tools yesterday.
Originally, I was going to stick a "full" Cman top box in my new trailer. But I have HF 44 box and I think that will be enough. I still wanted some screwdrivers on that side of the garage so I picked up the Cman 17 piece set for $20. While I haven't been impressed with Cman screwdrivers, their cost was just over $1 each, made in the USA with lifetime warranty and won't get much use in the trailer. I believe they will be alright for the job.
The blades, I'm unsure about. I have some thin aluminum angle to cut for the trailer and hoping the larger one will work in my Dewalt miter saw. ... although I'm not really keen on using it to cut metal. The smaller 7 1/4" blade, I'm going to try to cut the aluminum sheeting with rather taking it to get sheared or using a jigsaw.
The bit holder and magnetic parts are from HF. I used a coupon to get the tray for free after the purchase of the bit holder. ... $2 plus tax investment.
lightning02
i have some of those screwdrivers i bought about 2 years ago. made in the USA. some of the shafts where bowed. the tips on phillips don't last long at all. maybe you will have better luck then i did.
NUTTSGT
That's why I was leery on buying them. The ones that I bought years ago in my regular tool box don't get much use as I know their faults...like you mention including tips that break off the slotted ones. I won't be doing much at the track but they "should" be ok for their intended use. . . . I hope. :dunno:
lightning02
I used a Phillip to change 2 light switches in my house and a rear brake like on my pickup and the tip was already fucked up lol I now let my father use then when he needs to use my tools bc I know how hard he is on tools and idc if he brakes them lol
colin39
Ok im a sad sap but hey i like the facom nano sets the top left is my original one
As it is again, these other 2 came up too cheap over the last couple of weeks
Nice i likey
Tyguy1209
Some stuff from cornwell guy. All this was stuff in his sales flyer he had listed cheaper but didn't have any in stock. Except the light, he had to order that. Took 2 weeks I love it!
Sent from my SAMSUNG-SM-N900A using Tapatalk
nickjj
Bournemouth UK
Few new bits for me
3TV
How do you keep your tools so clean and scratch free?
:moon:
The circular saw was looking pretty rough a month ago. I had tried cutting a few cement landscaping blocks with a masonry blade and running water. After three battery changes I decided it wasn't going to work, and used our diamond blade tile cutting saw instead. I finally got around to washing the circular saw, and scrubbing all of the dirt and masonry grit from every nook and cranny about a week ago. So it had just been cleaned a few days before the picture. The other tools get wiped down after use, and don't get that dirty anyway (drills, bit driver). The angle grinder and reciprocating saw are new.
MattVette89
SW Chicago
I've been on a Snap On buying kick the last couple of weeks. I picked this up the other day locally. Mint condition older set up to 1":
I needed a T6 the other day and didn't have one. Bought this and the Ernst rack off eBay when the $15 coupon was available:
Skin
Boston
Some newer and older acquisitions.
MAC 1/4" Impacting Air Ratchet
MAC 3/8" Right Angle Drill
MAC 1/4" Offset Sealed/Flat Air Ratchet
The 1/4" impacting ratchet was a bit of a disaster. Picked one up cheap ($50 or so) on Ebay 4 months ago only to find someone replaced the motor vane base and lost a spacer for the air motor then bought a second ratchet that looked like someone, at some point, opened it with a pipe wrench and peened over all the bearing shields hammering on them with a punch. My used air tool purchases have been more miss than hit for sure. Anyway I made one clean and complete air ratchet out of both and installed a little SP air tool battle hat on the head I had sitting around. Works great.
tonyciambrone
Northern Illinois
A selection from recent Cripe Distributing purchases...
Gedore pliers- I like the wire strippers for doing solid and stranded house wiring (and they are 1000v which is why I got them), not so much for speaker and automotive.
All the other pliers have gread fit and finish.
Nupla made deadblow, sliding T-handle to go with the not pictured 9 and 5 inch extensions, also excellent.
Gedore at these prices is well worth it I think. :thumbup:
Irwin countersink and step bits.
Williams 18" (china) adjustable.
Gearwrench E-torx sockets and Sunex Triple Square/XZN
Revelations
Gedore at these prices is well worth it I think. [emoji106]
Sent from my SM-G930VL using Tapatalk
losvre
UK
Hi Tony,
How do you find these Gedore strippers? Are they easy to adjust and to operate? How good they strip down to the wire?
I am thinking to by that Gedore as well or the similar automatic one.
Thank you
Sent from my HTC Desire 620 using Tapatalk
tonyciambrone
Northern Illinois
Hi Tony,
Thank you
Let's say you are going to wire a circuit panel with 50 12 gauge connections. You get it adjusted to the 12ga wire and it cuts very nicely.
If you are stripping 12 ga, then 10 gauge stranded, then 14 ga then metric wire, you will be tired of adjusting the thumb wheel quickly.
Can't speak to automatic wire strippers.
nanofrog
Automatic all the way. :thumbup:
Much easier to use, more comfortable, no figuring out which stripping nest/hole or adjusting the thumbwheel, and it allows you to set the strip length.
FWIW, mine is a Pressmaster Embla. This particular model is even more useful & cost effective as they also make blade cartridges for larger wire and Teflon/Tefzel/PTFE.
JRC3
Southwestern OH
I was being a smartypants accusing you of not actually using them. :p
0neFlash
Romania
Just got my new pair of combination pliers :D !
Tyguy1209
Fuel pressure tester from pep boys shop bought me 1bbd5c88b8d2ee0020b3ec4853dc7b8d.jpg
shoggoth80
Seattle
Been a bit since I added anything new.
First is a long handle 1/4" drive I impulse bought from the parts store. Because leverage, reach, and increasingly hard to reach work spaces.
The second was a warranty exchange for my Frankenratchet that finally stripped out and bit the dust. Since the Roto was the same price as the replacement tool, I grabbed the Roto, because I've found the flex joint to be more reliable than other flex head styles.
170-3tree
Today was tool truck day. I was planning on getting a 3/8" torque wrench for doing engine gasket work and was doing some today so bought this snappy electric type. I like it! So far. Gonna take some getting used to with the buzz instead of the clicks, also need to read up the instructions about all the feat.
I needed a compression tester yesterday, my old one was at my parent's house so said whatever and got a deal on the snappy one.
Also have order on their new BIG impact driver set. Then were gonna order my power top.
R_einan
Eastern WA
One of the flex 3/8 hard handle ratchets in yellow, the shorter mate is back ordered until later this month...
bodyguy16
QC, Canada
Picked up a brushless set yesterday, tired of bring tools or batteries home for the weekend.... haven't tried them yet.
Sent from my SM-G903W using Tapatalk
KMdef9
The Motorcity
Is it normal for the letters to be painted in like that?
I don't know that I have ever seen that before. Or at least noticed. :dunno:
Been doing this for a while at work. I don't use a scraper though, I just use Kroil and lightly run the surface paint off.
Just ***** when you get brakefluid on your wrenches, dissolves the paint pretty quick.
kball
SoCal
Picked up this stubby 1/2" drive from the Snappy truck and the Astro 3" cutoff tool from the Corny truck.
losvre
UK
Hi nanofrog,
Thanks again for your input. I was considering that Gedore above or the following one made I think by VBW just because you can strip a wire very close to the end.
View media item 62942
It seems that all automatic strippers they have about 10 mm or 1/2 inch part of their front dedicated to grip the cable.
Please also note I am not a pro electrician just DIY everything professionally:)
Thank you
