Wrapping hot air ductwork
Junkman
Northeastern CT
I was talking to the ductwork installer today, and he said that they no longer wrap the ductwork, since wrapping it doesn't give much insulation. From memory, I think that he said the wrap was a R-6, and that the cost of the material and labor made it prohibitive cost wise. He suggested that if I want to wrap it myself, that I should use bubble wrap with the silver outer layer, and to use spray glue to hold it onto the ductwork. Looking for additional opinions on this matter. thanks Junk
Jess
Vancouver Island, BC Canada
Tape all the seams with foil tape. That will reduce a large amount of loss in a system and either keep the heat or cool in. Cheap and worthwhile fix if its not being done at installation.
NUTTSGT
Northern Central Ohio
When I ran the duct in the garage this past spring, I bought some flexible duct with teh intention of running the sheet metal duct through it. It would have been fine but I wasn't able to do it in the confines of the attic. I cut it apart and wrapped the duct work after it was installed. Once that was done, I wrapped that with bubble wrapped and used foil tape to seal that.
http://www.garagejournal.com/forum/showpost.php?p=5669856&postcount=2162
J
Junkman
Northeastern CT
Some of the ductwork is the flexible fiberglass with a plastic coating. Would you wrap those also? I am thinking of having the attic roof rafters sprayed with insulating foam, and at the same time, have them spray foam all the ductwork.
csp
Franktown, CO
Is the ductwork in the same space that's heated (conditioned space)? If so, you don't need to do anything other than seal the seams.
ambenz
NW Chicago Suburbs
My ducts running in the basement for discharge in the main floor were never insulated.
I would loose a bit to the basement space as it wasn't finished.
Now that I added a drop ceiling and a few vents to heat the basement, the heat loss off the un-insulated ducts get "trapped" between the drop ceiling and main floor creating a warm floor through out the main floor! Kind of like a radiant heated floor. So no big issues in my case.
NUTTSGT
I think I'd becareful of that. I'd be worried that the spray foam might expand and push in the the flexible ductwork creating internal restrictions. :dunno:
tab2
Boston
Ductwork that is not exposed to the ambient air it is conditioning must be insulated in MA commercial buildings. Does it help? I can't tell you that, but it is what is enforced by inspectors here. It is typically 1-1/2" fiberglass based with a foil face. I'm unsure of the R value. Exposed ductwork does not have to be insulated.
I think using foil tape and duct seal is more important to not lose any conditioned air. Spray foam is expensive, I don't think it would be worth it on the tin.
