signcrafter
- Joined
- May 9, 2012
- Messages
- 12,605
I needed to remove some glued down commercial carpet and some glue down vinyl plank in a building. We pulled the carpet and planks up and then had to deal with the glue left on the concrete. After some research I ended up buying a diamabrush plate that goes on a floor machine, https://www.amazon.com/dp/B00LG1HUSW/?tag=atomicindus08-20. Figured I could rent a floor machine for a week or two for a couple hundred bucks but ended up being about 200 a week to rent. So I ended up just buying one for around 650. https://www.amazon.com/dp/B001RQ2ZF4/?tag=atomicindus08-20. Just how my head works since I hate renting anything and it was paid for on this job and I'll have it for a long time to come. Plenty of material left on the diamond wheel also so can use that on any future projects.
I got the work done and now have a floor machine and diamond wheel sitting around. So want to see what else I can use this thing for?
Can I use a floor pad like this https://www.amazon.com/dp/B005AX12HC/?tag=atomicindus08-20 to clean things like epoxy floors, ceramic and porcelain tile floors, or other things? If so what color pads work for what and what else can it clean?
Or would a bristle wheel work better for cleaning tile like this one, https://www.amazon.com/dp/B01011RZYG/?tag=atomicindus08-20
I see they also make a driver for using 17" sanding discs, I'm guessing for sanding hardwood floors? How good are they compared to a drum sander I'm used to seeing for hardwood floor sanding?
I've also read about using a bonnet for cleaning carpets. Not sure I would want to try that because it seems a little dangerous in a smaller residential room to clean a carpet stain.
But just wondering what all some of you might have used a floor machine for? What different drivers you might have used and for what? Any other tips for floor machines like these?
