Whole Property Generator
bcoke
Pawlet Vermont
Yes I know it usually is a whole house generator [standby] and I could do two of them..........BUT I have three buildings on property the main power comes off one pole........two services, one to the main house, the other to a house/workshop with a sub panel in the detached garage.........both services are 200 amp panels respectfully..........NOW the big question would it be possible to have one large standby generator at the pole connected with a transfer switch to supply both services with power during a blackout [ these come a few times a year as we are at the end of the line ,so last to get power back] .... I would not run both services using full power, just heat[burners],well,refridge;freezersome lights etc. Has anyone done this????? It would only make sense if less expensive than two separate who house standby systems............Thanks of any and all input>>>>>Bobbycoke
larry_g
oregon
Anything is possible. Your only limiting factor is your wallet. How big of a load are you seeing in the out buildings? Do you want an automatic system or manual?
lg
no neat sig line
jconnor3
Indianapolis, IN
That's how my grandparents farm is set up. One big generator by the pole. We store ours though and bring it around with a tractor and there is a special hook-up at the main pole. Sorry I have zero details on it though, just know it's doable.
bcoke
Pawlet Vermont
AS I am set up now it would be before the meters, but I assumed the meters would have to be moved from the houses to the the pole, than the transfer switch or switchs.........would run on propane off my 1000 gallon tank [buried],,,Of course all electrical work will be done by licensed electrician and with electric company's input........just trying to get the feel of the knowledge we have here on the board so I can ask the right questions of my electrical contractor and have some knowledge of what's right and whats wrong......thanks Bobbycoke
theoldwizard1
SE MI
Or redo the service where you would have one meter
Unless you are getting a special rate for one of them this is the way to go.
Just make sure you have 4 slot - 400A load center mounted close to the one meter. The "transfer switch" (a 400A DPDT safety switch) will cost you an arm and a leg ($,$$$) and it gets mounted between the meter and the load center.
I hope you have deep pockets !
txvwnut
Bedford, Texas
Price shouldn't be too bad. Then gen set probably runs around 10 to 15k used for your power factor and a switchgear should be around 20 to 30k installed, and will need to be installed between the commercial service(meter) and building(s) being supplied. You'll need a good weather tight building for the switchgear to be installed in too. All of the ones I'm responsible for are in air conditioned buildings so that's something else to consider.
budmur
Athens, TN
If the transfer switches before the meter, you'll still be paying the utility for electricity provided by the generator.
