Harbor Freight tool cart review - 95659
fatrhino
Rochester
I bought this toolcart from Harbor Freight yesterday, so heres a little review of it.
The cart is item number 95659, and here it is on the website:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=95659
It is normally $189.99, but on sale for $89.99 during the sidewalk sale. Combined with a 20% off coupon, it rang up to 71.99 before tax for me. On to the pictures. Click them to make them bigger
Here is the box, not that big, but pretty heavy.
Opening the box, here is what you get. Styrofoam does an ok job of protecting, but not total coverage.
The rest of the parts (legs, casters, bolts, handle) all come inside the drawers. Here are the legs, wrapped up in some nice camouflage paper :lol_hitti
All parts unwrapped and spread out for assembly.
No pictures of assembly, but it is about 50 little bolts. Here are the only tools that I used to assemble: 1/4" ratchet with 13mm socket and 13mm combo wrenches. Also notice the foam liner. This is included for all drawers, the top compartment as well as the bottom shelf. In this picture you can see the holes for prybars, screwdrivers, etc as well. They are on both sides.
Here is the top 2 drawers with a 12" rule for reference.
Middle drawer
Bottom drawer
Bottom drawer depth - 4"
Height from ground to top of closed lid, reads 38"
Width
Depth of top lid
And finally the finished product, and it is out of focus! DOH :Homer:
My impressions
I am very happy with this cart for what I payed. I do not have any experience with truck brand carts, but I think this is a well made cart.
I like that I am able to put my deep 1/2" sockets upright in the deep drawer (on clip rails, Hansen trays might not fit).
The finish (powdercoat?) feels decent as well.
I like the fact that there are plenty of holes for screwdrivers and prybars to hang through in the top compartment, but that leads to my first complaint - the brackets that the bottom of the cabinet sit on are directly underneath the holes, so longer prybars hit this. I plan on drilling some holes in this bracket to allow things to passthrough.
The casters, drawer slides and top lid hinge/supports are all a bit stiff. I am sure that this will get better with some break-in and some better lube though.
The slide detents are also a bit strong, but I guess strong is better than weak.
I would recommend this cart, and expect it to hold up well. If anyone is in the market for a cart, I recommend you print a coupon and get to you local HF before the sale ends tomorrow. Also, keep checking back for reports after some more usage and some pictures with it full of tools.
:beer:
Don 18
Buffalo NY
$72 is a great price for that. I've had mine for 6 months now, and its held up fine for my light duty hobby use.
Don
Joe Mamma
Awesome review. Thanks for posting this. At that price, even if it lasts for just 1 year, you got a deal!
Joe Mamma
pearl_dude
Sanger, CA
I just bought mine today and assembled it, and it seems really sturdy. I had to get it since it is about $100 off.
back2class
Got one too. It is good quality item. Quality seems to be better than craftsman and lower than tool truck stuff.
The locking system is pretty flimsy but ok for home use though it can bend and break easy. The steel is pretty heavy and not thin. Pretty good hard rubber ball bearing casters.
I hate the screwdriver holders as they are not deep enough for long shafts as noted in the first post and any longer handles stick up too high to let the lid shut. I also do not like the fact that the lid has to be open to open the drawer. Slides have decent action and positive shut position.
Overall better than any home shop needs but too many shortcuts to hold up on daily heavy commercial use. The unit is built well, just a few cheep shortcuts holding it back for being good for long term daily use in a real industrial setting.
I never buy new, but at this price I figured it was worth it. But I like the basic Kennedy 5 drawer with storage on bottom and wood top better. That way you can store things on it. I think this new design is not better than the old carts, just a passing style.
Danglerb
SoCal
I bought the plastic one, same as Rubbermaid as far as I can tell, on sale for $89 back in pre 20% coupon days. Took it to a commercial shop and it currently has or has had almost a complete motor on it, with just a touch of sag when the block was on the top shelf.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92862
Pictures of all three below, grey plastic, black sale, red heavier non sale model. Very tempting to get the sale cart, so convenient to have these carts as tool storage and work surfaces.
Grey is 24x36x33h, wt 43 lbs, rated 500 lbs.
Black is 17x33x38h, wt 102 lbs, rated 580 lbs.
Red is 21x38x41h, wt 138 lbs, rated 700 lbs.
Rickster
SE PA
When you get it all loaded up, how are the wheels? Also, how is the body flex when pushing fully loaded? I built mine from a HF three tier cart by adding a Craftsman 4 drawer mid section. I found the HF supplied wheels to be too soft and narrow for stability. So I added harder and wider wheels and a 3/4 plywood board on the bottom that I bolted through to the wheels to reduce flex.
Matt M PA
SE PA
I too have the grey plastic one and have been well pleased. In fact, it has had a '56 Olds rear upon it, a Superbird nosecone...and it used for all sorts of other activities.
WSMC633
Los Angeles, CA
I've had mine fully loaded and it routinely get's drug all over the shop. Never had any flex or stability problems.
It does drive me nuts that the top area is not deep enough to hold must screwdrivers without stopping the lid from closing. I ended up just using the holes to store extensions.
I think it's great for the price, but it's little things like screwdrivers not fitting that really take away from it.
Stick Figure
Omaha, Ne
i use one of my every day at work, and i have another at home. never had a problem w/ them rolling or anything else and you can see how loaded they are here: http://www.garagejournal.com/forum/showpost.php?p=564784&postcount=2163
the home one isn't as loaded now since i've obviously run out of room in it and have bought a small craftsman box to share the load. I have drilled out the lower rails in mine to accommodate longer items, as well as opened up the holes in the top to allow some of the screwdriver handles to drop lower so the lid will close. Luckily for me i really don't use a screwdriver on a regular basis, so i don't keep too many in the cart. I would like to find a side shelf, and prybar lock box that fits this cart. Either that or when i get time i am going to make one for it.
Danglerb
SoCal
Screwdriver and prybar lockbox thread.
http://www.garagejournal.com/forum/showthread.php?t=44554
Ray-CA
San Diego CA
Our local store is having a "side-walk" sale this weekend with that cart marked at $89.99. I also have a 20% off coupon (down to $71.99.) Looks like I'm heading to town.......
Ray
back2class
Ok, looked at it and compaired it to my two other boxes. A stainless costco CSPS from 2004 and a 80's vintage Knennedy 5 drawer cart. I owned a snap on when I purchased the csps and it was sub-par to the CSPS. Same snap-on box in this thread http://www.garagejournal.com/forum/showthread.php?t=44866 . Man, my first and only SO box was a huge letdown. I am not crazy about my CSPS, but it was light years better than that big red overpriced turd. Now back on topic.
The HF cart uses the same exact middle of the road ball bearing slides that the CSPS box uses. Attached with a few (could use a few more) pop rivets. They are good slides and not junk. The steel used is heavier gauge than the Kennedy or the CSPS. Casters are better than on the Kennedy but not as nice as the csps. Everything lines up well. The system that locks the drawers shut is pretty simple but a-ok. To me after looking it over it is a pretty high quality item and I dispise HF tools as well as most everything else they sell.
Good steel, good parts and all lines up well. Is that not the basic stuff that makes a quality box? I find it hard to imagine the big names are much better.
It does lack some design refinement that my other boxes have, the key lock is a joke, the push handle is a little cheap looking as are the chrome drawer trims. The lid hinge is nicely welded to the top but pop rivited to the box when it should be welded and the part where the screwdriver holders are a bad design and a real PITA. It is not flimsey or made with inexpensive materials.
But for general quality for doing its job..WOW! For $72 it is a well made though perhaps not "refined" hunk of steel.
supertooljunkie
Lilburn, GA
I have one of these I bought 1-1/2 years ago for $100. It's great. I have mine loaded out for general repairs, then add the special tools for specific jobs. It is much easier to drag this down the driveway than a full size box, or run back and forth. I have pulled mine down the street 2-3 blocks to a friends house with 200-300lbs. on it with no problem. I would buy another one but at the moment I have 10lbs. of **** in a 5lb. garage.
crashbumper
Gilbert, AZ
Sorry to dig up an older thread; but I had some questions:
Is the top deep enough for hansen trays, or the HF knockoffs?
How has the lid done with use? I noticed it has a locking hinge instead of gas cylinders.
SkyPuncher
Sorry to dig up an old thread, just happened to notice they are on sale now until Dec. 3rd for $99
