Wow. That gate looks great.
And the speakers look nice.
What brand of speakers are those soffit units?
Fabulous.
Thanks for showing the CAD drawing. How much $ was the SS and how much to have it cut/brake?
Can't wait to see the garage rocks.![]()
Anyone on here good with speaker wiring? The only issue I'm having so far is with my speaker splitter. I should be able to control each pair with the push of a button (buttons 1-6 on the selector in photo above), however if ANY single zone is selected to be on, ALL the speakers (4 pairs/8 speakers) all come on.
Any ideas?
Impressive build.
Love the attention to detail.
Do you take your car out to the track? And if you do, is it NASA events? If so, I bet we know some of the same people.
OUTSTANDING BUILD! I have to ask about the gutters...typically they would be one of if not the last thing added. Did you seal and paint behind them before install or is everything behind the gutters unfinished? Just wondering...
On your countertop dust port - could you cover it with magnetic vinyl for a more flush surface?
GREAT build thread. I've really enjoyed reading it.
Where did you find those adjustable feet that go in to the steel tube??
Thanks
Really nice garage! Did the concrete from the side overflown and raised the level of the lift pads inside the form at all when it was poured? What psi concrete was poured?
Great idea! I might glue some rare earth magnets on the underside of the counter then cut a piece of sheet metal slightly larger than the opening and have it stick to the top for a flush look.
A couple thoughts. I think you said that the counter top is mild steel, so glue would not be necessary. Second, using magnets this way would magnetize your counter top, at least locally. I think that metal bits would stick to it, and make it harder to clean or get sucked into the duct. The vinyl/magnet cover would be much weaker and when removed, would break the magnetic connection.
Man, what a cool build. I really like the aesthetic you've created, top quality job on everything. I dream of being able to build my own shop one day and deck it out the way you have.
Also, just a quick tip for you. I've noticed that you respond to people in separate replies. If you'd like to reply to several people in one post, you can click on "multi-quote" on all of the posts you'd like to reply to and then click "quote" on the last one. It will lay each comment out in the order that you clicked on them. Makes for a cleaner, less cluttered thread in my opinion, just thought I'd pass that info your way in case you didn't know.
Anyways, awesome work on everything and I really enjoyed reading through this thread. I should really get off my computer now haha.
