Hi,
So I'm just getting started on my own car repairs. I went to change the serpentine belt and check tie rods yesterday and I ran into unexpected difficulty related to jacking and jack stands. I wasn't comfortable with how car sitting on the stands so I dropped the car and figured it would be best to ask here before getting under it.
The car is a 2010 Ford Edge. Being a unibody, it wasn't completely obvious the best place to jack it for placement on jack stands. After I settled on a spot to jack it, I got on my side and watched closely for any signs that it couldn't support the weight while jacking and got it onto the stands.
The photos below show how I jacked it. It's obviously strong being part of frame where control arm attaches and there's a vertical column right above jack point.
The first is a photo shot from front of car:
And this is from side facing front of car:
The problem as I see it is that the groove at the base of the jack stand's saddle is too deep for the ford-recommended jack points and so they don't fully seat into the saddle. The high points of the saddle contact to the sides of the jack point instead of being properly seated on the pinch weld. Not sure I'm comfortable getting under car with this arrangement... If anything slipped it could drop a centimeter, and I'd be worried about the ends of the jack stand pushing through or deforming the metal it is in contact with on either side of the pinch weld.
This photo shows the car resting on jack stand at the front left lift point:
Could there be better spots to place the jack stands where I don't have to worry about this?
This photo is from the Haynes manual showing underside of my car:
FYI I should have used letters instead of numbers, but when I refer to numbers on diagram, I'm always referring to the numbers in yellow that I added.
#1 looks like part of the structure of the car and the metal is doubled-up in that area. That said I don't know what the overlap of the two metal pieces is. Might only be an inch. I watched a video that said these are typically ok places to jack at or put stands #2 is where I jacked from. The jack has a big circular surface but #2 isn't flat, it's slightly curved, so the jack wasn't in complete contact there but jacking it was ok. Given the saddle shape of jack stand ends, I'm not super comfortable about using jack stands there... Also wondering if I can jack entire front of car at point 3 (in yellow) of pic below? Would mostly be for convenience vs the point I chose that's more difficult access and to lift from.
Here's a close-up of area 1 and 3 (both in yellow)
area 1:
area 3:
What's your advice? Thanks in advance.
area 1:
area 3:
