Goodbeorning
- Joined
- Oct 20, 2016
- Messages
- 5
So I'm not a terribly experienced electrician. I'm a stage carpenter with some electrical knowledge. I follow a lot of your guides when it comes to doing work like this. But enough background.
I'm replacing outlets in an old condo when I came across this setup (picture attached).
2 neutral attached to the outlet
1 hot twisted with a second hot and a neutral attached to the outlet.
1 hot twisted to red.
No ground (anywhere in the condo, so far as I've seen)
It looks like the end of a sequence to me, but I've never seen this before and I'm not sure what to do with it other than wire the new outlet the same way.
Any advice?
Any advice?
OP needs to verify if the j box is grounded.
