This is a seriously zombie thread. Further, it is filled with semitruths. How much current to use? The correct answer is not given in amps. It is given in amps per square inch of part. If you had an old tractor in a pond being derusted (extreme example) using a ten amp power supply would take a very very long time to clean anything. If you're cleaning an old pair of pliers, ten amps would be really a lot. Personally I suggest 125-150 milliamps per square inch.
Also, if you use one of those small buzzbox battery chargers (e.g. Schumacher, Craftsman, etc.) be aware that although they don't say it those things have a max duty cycle. I don't know what it is, but if you EDR part after part with no rest between very soon you will find that you have cooked your charger and now it won't work anymore. I now use a proper DC power supply. It isn't extremely powerful, max 30 amps and 30 volts. But you can use it for a month without it overheating. Also, I generally use it in current mode which means the power supply will raise the voltage as needed (again, to a max of 30) to keep the current constant. If you use mild steel as a sacrificial anode, this will help with the process slowing as the anode corrodes.
I use sheet lead for anodes. Same as they used for the roof on Notre Dame cathedral which has been standing since what - 1050AD? Yes, lead oxide forms (slowly) but lead oxide is just as conductive as clean lead metal, so the bath stays clean and clear and the current stays constant even if you do use a cheap battery charger which acts like a voltage source. You do have to take lead anodes out of the bath afterwards or the sodium carbonate will slowly eat them away. Little lead anodes I rinse off in the shop sink and big ones I lay out in the driveway and pressure wash. One of those rolls of lead sheet from Amazon will last you many, many years.
If you are doing something like an old vise, where you just want to blow through paint and rust quickly, use a high current. If you are derusting an old pair of Zeiss jeweler's glasses, use a very low current. The lower the current the less iron carbonate (black stuff) will be left on your part.
I tie my parts with iron tie wire and suspend them from rods placed over the bath. I generally use a little excess tie wire and leave it bent in a double loop up in the air so I can easily clamp the power supply wires to it. Yes, you can run 30 amps through sixteen gauge wire without it overheating. Remember, it runs through water, so it's continuously cooled.
And on and on ..
metalmagpie
