Ugly walls.
Trans damm
My garage has some terrible cinderblock walls. What's my best option to make it look better. I would Sheetrock it but I don't want to lose that much space after I stud it and I would like a cheaper easier approach. What are my options. I see Home Depot sells some cheap 4x8 white plastic panels, I was thinking about maybe glueing them up. Here's a pic.
bczygan
DETROIT! Arsenal of Scrappers
Metal lath and plaster?
Or play up the roughness and coat with high gloss bright white paint. I did with a brick wall and it sparkles. There's nothing wrong with a rough texture to counterpoint and complement the smooth look of cabinetry. It gives you that industrial look.
Bill
davejo
(VA)
do some sort of a chair rail accent with wood or some cool tile then two tone paint job.
The Frp panels might look pretty sterile in there
T
Trans damm
Over here we would glue drywall on with bonding compound, you only lose an inch. Or render and plaster it.
Wouldn't moisture become an issue right up against the wall. I know in the winter when there cold and I turn a heater on you can feel the moisture on the walls.
cowboy73
southern Indiana
You could tapcon some 2X2 furring to the walls and then drywall it. You would only lose about 2 inches of floor space that way. You could put 1.5" Styrofoam between the furring to gain a little insulation.
NUTTSGT
Northern Central Ohio
You can feel moisture because the wall is sweating just like a cold beer can in the Summer.
Since you don't have your location listed, we can't tell where you are but sounds like you do get a cold winter.
I know you don't want to lose space with studding up the wall but I would still do something like that. I would tap-con furring to the wall vertically and along the top, at the bottom use a PT 1x4. Once that is done, glue some foam insulation in between the furring strips or duct tape will work temporarily. Then add some 7/16 OSB, plywood or drywall and screw it on but leave a small gap at the bottom so it is off the floor.
This will do several things for you,
Cover up that "ugly wall".
Provide you with a small bit of insulation, R3-R5, depending on which foam you choose.
Having that wall insulated, will help retain heat and create a thermal break from that block wall sucking heat out of your garage, this in turn saves you on heating costs.
Covering it with OSB, plywood or drywall will give you a place to hang some lightweight things or signs/banners. They are also softer if you accidently open a car door into them.
Using furring strips and 7/16" or 1/2" sheets, you will only lose 1 1/4" of floor space, well worth it for what you are gaining, IMHO.
NUTTSGT
Cowboy was posting as I was typing....great minds...
DCarr2
Akron NY
Bill
Emphysis mine
I doubt he wants to spend $2,000 on one wall lol
moisture barrier - read heavy plastic
furring strips, drywall.
prime paint. might lose 2 inches.
wolfhawk73
Eastern North Carolina
I'd use furring channel (hat channel) instead of strips since you said you have moisture issues. I wouldn't want to put wood directly against a wall that sweats.
http://www.clarkdietrich.com/products/drywall-framing/furring-channel-hat-channel
Roberts210
Missouri
Ditto on Stucco. It's a cinch to apply and will look great. Watch a few Youtube videos and Use a pool trowel.
