I was wondering what degree off set you guys prefer on your DBE if you only had 1 set?
I only have the 0° "high performance " DBE. Never saw a single reason to ever consider buying any other offset.
What I was taught the proper tool for the job.
You maybe can get by with the wrong wrench but using the correct wrench you reduce the possibility of damage to bolt/nut and any other items in the area.
I look at my hi performance wrenches with 0 offset and think there is a dozen jobs that they would not work.
Never once found a bolt that a deep offset DBE was the only.
Both is better!For me, I prefer the one on the far right. I like the knuckle clearance and the ability to get into recessed areas better. But, depending on what you are working on, the left ones (15° offset) might work better.
That's why they invented sockets. Never once found a bolt that a deep offset DBE was the only option. Only reason I have 0° DBE is because they were too cheap to pass. I use them because I have them, not because I need them.
Reg size DBE - 60 degree
Super long DBE - 0 degree
You get the 15 degree for free on your combination wrench box end.
Only one set? - Reg size DBE 60 degree
