The VISES of Garage Journal
JohnFreeman
central nc
My recent Craigslist find (needs oiling to remove surf. rust) COLUMBIAN, apparently by Wilton.
I see I left one soft jaw in it. A photographer I am not.
06wt
chicago 434 UNION CARPENTER
Don't know. Stamped on the fixed jaw is HI-TEST, NO. 327 and Made in Poland. And there's a logo I've never seen before cast in the side.
One of my neighbors gave it to me, he said it was his fathers, who had it for how long he doesn't know.
Andy
well hopfully some one on here can help us out.
thanks for the further info andy
murph64
Mohegan Lake, NY
I have one of these also, picked it up from HomeyD's a couple of years ago. The rotating jaws came in handy a couple of times.
Andy
mjozefow
Lafayette, IN
So who's got the biggest (width)? I think 6" is the leader so far...
8" jaws on my Wilton 1780. So I think I'm in the lead so far.
Who has the heaviest? My CP is 140ish. Anyone here have heavier? Those Records look pretty beefy.
W-Cummins
Iowa
Your CP @ 140# is all most 1/2 a vise, as for the little wilton @ 110# It's only a little bigger than a 1/3 of a vise :):)
I suppose I'm now going to have to re-post the pictures of the CP 978 @296#
William....
bmwpower
William....
I knew you would do that... :)
I know how to bait you....
snapmom
Florida
the Soderfors looks like it would be a very good working vice, lots of room to position your items.
W-Cummins
Iowa
Yes. yes you are.
:thumbup:
Andy
ok I guess I can
Now I feel abused.....
William....
So the pop can might allow for some size perspective....
And the other side
And the Front I need to replace the finger saver...
I don't think that I will repaint the vise as I really like the patina it has now might wipe off some or the over spray on the jaws from the years of painting what was held in them....
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
How can you tell a Wilton? The one we have at work looks pretty close to that one, with the rounded closed back, and has the same "Made in USA". But it doesn't have a name anywhere I can see.
The above one, is an import. If you find a used one with the round shaft, that DOESN'T look like the above, chances are it is made here. The above one matches all the imports in that style, in different colors. (I have one for outside, light duty use)
Now Columbian vises, used to be made here, and there is old stock of them (they cost), at places like Harry Epsteins. Wilton bought them out years ago, and then they started using them as the import line (available at the borgs under $100). The old method of (the above exception) was round shaft, made here, square shaft, made elsewhere, unless you found old marked Made in the USA.
Now it was discussed (last year?) that Wilton has dropped at least one size and is importing components. The one size they dropped is now sold at Sears, in the same tensile strength (doesn't open as far though) for $129 as their USA models. The model is 87018.
As you can see, not exactly a straightforward answer.
greenreese
So wait, the one I quoted is an import?
I'll be back, going to take a pic of my newfound vise...
wantedabiggergarage
Member Emeritus
Pictures didn't follow posts. The one JohnFreeman posted is an import (round shaft import). The one you showed, is either made in the USA, OR a combo (USA of globalized components), that they now also produce the Sears one, at an offshore factory.
greenreese
How's about this one? Got this a couple days ago from a friend who is a retired auto mechanic. It swivels and spins. I haven't seen one like it before. Can't read anything on it. Opens to 5in and is mounted on a 1/4 plate homemade table.
old salvage
Rhode Island
Loving the tool **** in this thread...
My 2 main vises. A 4" Reed and a 4 1/4" parker that is my biggest at 80 lbs.
A ww2 era Craftsman 3" jaws.
3" jaw Wilton
My favorite vise. I dont use it anymore since it needs new jaws. A Rock Island 574. ..
Athol Machine Co with 3 1/8" jaws. This vise has 'No 79' cast into the body and '1884' cast in raised numbers into the movable jaw. I wonder if thats a date.
Another Athol vise. This one has 1 1/4" jaws. Model No 3
mjozefow
Lafayette, IN
Mine has a plate on the other side that says Wilton.
William....
NICE! A rare instance where I am very pleased to be beaten out!
I want one that size. Where did you find it?
caper
cape breton
Wow that Craftsman is a little twin to the Reed.Not hard to guess who made the Craftsman for them.:beer:
old salvage
Rhode Island
Good eye. The Craftsman also has the Reed type split nut that holds the screw in the slide and the patented Reed threaded pin that takes up slop behind the main nut. http://www.google.com/patents?id=AodUAAAAEBAJ&pg=PA1&dq=reed+vise&source=gbs_selected_pages&cad=2#v=onepage&q=reed%20vise&f=false It even has Reed stamped on the inside of the swivel base.
ftp
Here's my beautiful Rock Island vise. I think it weighs at least 60ish pounds. The jaws open to just under 6". This thing is built like a tank. When I completely rebuilt my old workbench, I designed it around the vise. it works beautifully. I don't remember how much I bought it for, probably 30 bucks at the most. From the marks on the bottom, I think it dates to the very early 1900's.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
My Desmond Stephans vise. After seeing all of these I may have to tear mine apart this weekend and get it mounted to my new bench.
Displaced Hokie
Western NC
Mine...
Tiny one from a yard sale. Handy for soldering and small stuff. Well made little thing...
My main vise. Japan made, but belonged to my wife's father so it has sentimental value...
Just picked this up from a thrift store for $8 and would like to know more about it. It's bigger than my current bench, so I'm not using it yet. Was rust red, so I hit with some rust converter. It's a Simplex made in Ohio, USA. Says "The Desmond Stephan Mfg Co, Urbana, Ohio"
*Edit* I see the poster above also has a Desmond Stephan vice. Must have posted his while I was posting mine. What's the history on these?
Pat
Alowes2837
Not the best pic but they are adequate for most purposes
W-Cummins
Iowa
It was/is the biggest vise I have seen. I knew when I saw over 25 years ago I wanted it. I had to wait until the owner retired from his welding/fabrication business a few years ago. Then I made him an offer that we both could live with for it. Now I need to find some thing stout enough to mount it to. He had it attached to a table made of old growth doug fir 2X12's ( 8' long) standing on edge bolted through, to make a top 8'X3'X1' thick (think the table weighed more than the vise by quite a bit)
William...
Griff93
Huntsville, AL
Columbian Vise that was my Grandfather's. Still works great.
Morgan woodjaw vise that was also my Grandfather's. Its really nice for holding stuff you don't want to marr up.
Ridge Tool Co pipe vise. I love having one of these. I do a lot of round and square tube work so its really nice. I have it mounted to my welding bench.
Import 4 in drill press vise that I have mounted to my welding bench.
Palmgren 6" vise.
Import swivel mill vise.
banditbigdog
Southeast
2.5" Canedy - Otto
Small USA made Stanley
4" Columbian
Noga Arm with mini Kant Twist Clamp
Not really a vise, comes in handy as a 3rd hand
jamesemery728
Here's some of the collection
murph64
Mohegan Lake, NY
This little vise is well suited for small work. It was one of those pitiful vacuum mount hobby things with plastic parts. I mounted it to a block of wood I clamp in a larger vise and machined steel parts to replace the plastic.
yours Scott
Brilliant! I will be stealing, um, borrowing :drool: this idea...
Andy
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Mine...
Pat
Desmond Stephans has been in business for quite a long while. Not only did they make vises, but they also make dressers for grinding wheels on benchtop and pedestal grinders. I'm about three miles from where they are located. If anyone has ever been through Urbana, Ohio, they are one block south of the Post Office in town. I'll have to ask to see what they make total in the way of products. I'm not sure if I know anyone that works there though.
I know they still make dressers, but I don't think they make the vises anymore. We have quite a few of the older Simplex vises at work. I'll have to look at the other side of my vise to see if it is a Simplex or has a different name on it. It now has my curiosity peaked as to how many different Desmonds that we actually have at work. The rson that we have them is at one time years ago, Urbana used to be a real close knit town. It seems that everyone was related and the different factories in town almost always catered to other factories. That is why we had so many Simplex vises in our shop
