Ideas for Tray for Tool Box Drawers
cliftonbros89
Missouri
I'm searching for ideas to make trays for a few of my deeper drawers on my tool box. It's a 72" John Deere box. Basically the same as the 72" Masterforce, Montezuma, Tool Vault boxes (they're all made by QCI).
I'm referring to something similar to the trays Snap On makes for their larger boxes (Seen below). I need something lightweight but strong and sturdy. I'm just not totally for sure what to use. Or where to get it.
A few of the drawers aren't very wide. But I'd like to try and make a tray for the top drawer where I keep my sockets. So I could have more room for sockets and store ratchets, extensions, and breaker bars in the tray. But that drawer is right at 51" wide.
What's my options for material and where to get it?
rsanter
visalia ca
Find were you can use a sheet metal break and use some 16 or 14 ga steel and bend up the trays you need.
The paint or powder coat to match the color,of the box
See if there is a member close to you with a break, I have one you can use but am a little far away
Bob
R_einan
Eastern WA
If you can find something that fits into the deeper drawers and hangs from the drawer sides that would be awesome. In fact, I saved that picture to ask my snap on guy about them. If they are 22.25" wide they would work for me.
C
cliftonbros89
Missouri
That's my problem. None of the ones that Snap On offers are the right size for my drawers. But that's the type of thing I'm looking for.
R_einan
Eastern WA
Nothing that would help me either. Just for kicks I checked Mac and matco and come up empty. Maybe I'll take a quick measurement and stop by one of the local sheet metal shops and see what they would want to make a tray of two. Thanks for the link and the idea!
C
cliftonbros89
Missouri
I was thinking of the doing the same thing. I don't think they'd charge too much. But by the time I pay for the metal plus the labor of the brake I'm afraid it'll be more than I'd want to spend
C
cliftonbros89
Missouri
I'm wanting one to hang on the drawer for the full length of it. Deep enough to fit some things in but shallow enough things can still be stored under it. Like a removable tray in a handheld box.
Matt M PA
SE PA
I got a "box" that has ears. The ears hold it up on the edges of the tool box drawers and it slides from to back. By dumb luck, it fit my new box but was in my Craftsman box for years. I assume it came from Sears.
For my new box, I tried the Container Store. I didn't buy anything that would hang above from the edges of the drawers...but got some metal mesh boxes that have been great for keeping socket handles, etc by drive size. They have a huge selection of "organize-y" stuff.
I know one of the companies that made drawer organizers made pieces that went together and had a lip that joined them. Perhaps something like this could also hold them on a drawer edge?
gerryw
toronto area
Just a thought, have you checked out baking pans?
They come in all sizes, and depths, and most have a edge( handle) that could sit(or folded over) on drawer edge as you wanted
Gerry
NUTTSGT
Northern Central Ohio
To run the full width, you're going to need some strength and to be lightweight, some aluminum would be nice.
Since that takes a little different method to weld, it might not be practical for the normal person. Having a brake would be nice but it would need to be a wide one and that rules out alot of DIYers. If you make it yourself, do you have a mig welder ? Possibly some small round tubing to make a length wise frame and weld some sheet metal to that. The ends could be some slightly thicker sheet metal than the rest of the drawer and the only thing you would need a brake for.
C
cliftonbros89
Missouri
I was maybe thinking aluminum as well. I just wasn't sure how much it would cost. I know a few guys that could weld the aluminum for me. Just a matter of finding some that'd be the right size and thin enough. That's why I'm thinking I may have to go to a local service shop that does a lot of fab work and welding.
C
cliftonbros89
Missouri
I'm also not sure at full length what gauge of steel would be good to use. If it was say 4.5" wide, with the length I know I couldn't go too thin. But I don't want it to be too heavy either.
C
cliftonbros89
Missouri
Finally came up with a solution. Had some help with it as I don't have a brake to work with. Used 16 gauge steel and 3/4" angle for the hangers. Just made 2 for now. One for my drawer with some of my pry bars, scrapers, punches and chisels. Then another for my ratchets and extensions in my socket drawer. 0dc07bff9084172f516bb33ef93e0065.jpg
I cleaned them up a bit, cleaned up the corners. Then I sprayed them to match the box and put drawer liner in the bottom of them. I'm really happy with them. I'd say there's a chance I make make a few more later down the road as my box becomes a bit more full.
