L5wolvesf
ALL:
2) Grinding
don't grind aluminum
OK at the risk of sounding really dumb . . . why not grind aluminum?
ALL:
2) Grinding
Mythbusters proved that is bunk.I know hammering against another hammer is asking for trouble.
If, before I do something, that little voice in my head says, "I shouldn't do this", then I listen.
ALL:
anybody else benefit from reading this thread post up how maybe you've changed your ways? or did anybody get hurt doing something they knew or should have known that wasn't the best method of doing something post up those stories too.
cheers
I always make it a habit to unplug power tools every time I have to walk away from it, even if it is for 5 seconds. I have a little girl and the neighbor kids are always running around with her (they are all under 8). I make sure not to use power tools if they are in the vacinity, buy there is no sense in not taking the 10 seconds it takes to unplug and re-plug something back up just in case they are a half a second quicker than me at that one paticular time.I was using a Dremel last night. As soon as I was done using it for something (but not done for the night) I immed. unplugged it from the extension cord. Removes the risk of accidentally sitting on the ON switch or something, when it's just lying there.
ALL:
if there is better ear protection out there too does anybody have a favorite.
The jack stands. How should you position the "U" ?The biggest two things I see all the time is eye protection and not using jackstands properly. I've had a floor jack fail while lifting, and no way would I ever get under something not on stands. And especially if you're under a vehicle changing fluids, no way you want want hot used oil in your eyes.
< snip >
I learned to wear safety glasses the hard way when working under rust vehicles the rust will fall in your eyes every time...
< /snip >
