caper
Here's some pics of the movable rear jaw on my Parker.It's the only one I've ever seen that swivels like this.
Here's some of the collection
The mini ones are cool !
What brand ? Looks european
Starting from left to right, the 3 small ones are all marked Germany, the largest of these 3 is marked NAGER, Germany, the fourth one from the left was made by the Lowell Wrench Co., Worchester, Mass, USA, the largest one on the extreme right hand side is a #15 Palmgren Hand Vise.
You should make one then! Out of several very large blanks of steel.
ok I guess I can
Now I feel abused.....
William....
So the pop can might allow for some size perspective....
And the other side
And the Front I need to replace the finger saver...
I don't think that I will repaint the vise as I really like the patina it has now might wipe off some or the over spray on the jaws from the years of painting what was held in them....
It is, works like a charm.Looks like a woodworking vise.
Be careful what you ask for...
The project is in a holding pattern, waiting on a certain bandsaw to do the contour work!
The thrust bearings are tapered roller and the screw bushings bronze. The nut is steel, which may wear the screw eventually. I'll be installing an oil cup there.
For reference, the head is 2.25" OD approx.
The vise is protected by the roll pin at the head of the screw. It will shear well before the side plates reach the elastic limit. Thus, the vise should be unbreakable.
We'll see...
mjozefow said:I look forward to seeing your vise come together. Got any projected specs yet?
Great idea putting a shear pin in there. But it could be broken by torquing on something too hard that is already clamped, no? That's how I broke my last China vise. Steel shouldn't snap like cast iron though since it is ductile.
Mine...
Just picked this up from a thrift store for $8 and would like to know more about it. It's bigger than my current bench, so I'm not using it yet. Was rust red, so I hit with some rust converter. It's a Simplex made in Ohio, USA. Says "The Desmond Stephan Mfg Co, Urbana, Ohio"
Who made who?
I bet Simplex made the vise and it was property of Ridge Tool Co at one time.
I googled simplex vise and found this.
http://www.worthpoint.com/worthopedia/ridge-tool-ridgid-simplex-vise-catalog-86
But the Desmond Stephan's appear to be built before the Ridge Company.
ANyone know who makes this vise? I found it in the scrap pile at one of my customers, it had a bent shaft, which I was able to straighten. I'm happy with it for 2 hours worth of work , a couple of new bolts and a coat of paint:
Hi Murfman - Nice vise. Can you tell us how you straightened the shaft? Thanks.![]()
I chuked it up in my lathe between the chuck and a steady rest, and whacked it with a rubber mallet. Got it to within less than 5 thousandths total runout![]()
I thought mine were a fair size some of these are huge, I guess there is allways someone bigger. Here is a better pic.
Are Prentiss vises any good?
Better late than never. My Wilton Tradesmen
Hmmm. Hard to say. What size is it? Does it work or is it frozen?
