Single or dual point release?
ms fowler
Littlestown, PA _ 6 miles south of Gettysburg
I am nearing the time to order a 2 post lift. ( I think I have settled on 2 post rather than 4 post--but I change with the wind).
Is the single versus dual point release feature worth being an issue? Is having to release the safeties at 2 points merely inconvenient ( or not all that inconvenient) or safer (or less safe) than a single point release?
What other features are "must haves"?
Jlbc212
Northeast MA
A single point release uses a steel cable to release the remote safety lock. Steel cables have many varied uses ranging from suspension bridges, lifting garage doors, to releasing a remote safety lock. It is a nice convenience on a lift
egnorant
East Texas
I prefer the 2 point as it gives me a good chance for a final walk around to check for problems.
Bruce
Falcon67
Merkel, TX
Mine uses a single point. IMHO that's the best way because you can stand by the pump while lowering the load and stop/lock or reverse/lock quickly if something goes wrong, like crushing the **** out of a 2 gallon dog water jug because you forgot you pushed it out of the way under a lift arm. ;)
You want to tune the lift so that your locks snap over at the same time, so I'm not sure why a double release would be anything more than a PITA. Raise, push the lock release and hold, lower the load.
It should be standard practice to clear the lift area before lowing the load.
mmb617
PA
Sounds like knowledge gained through experience.
I can relate. I have these wheeled metal carts I use to hold tools while I'm working and once lowered the lift and caught a corner of one that wasn't quite clear. I noticed it pretty quick but not before it bent a corner of the cart down an inch or so.
Now it's standard practice to make certain the underlift area is clear before lowering. :lol_hitti
I didn't know there even was such a thing as a dual point release. I can't figure out what the advantage would be of such a setup.
lakeroadster
Central Colorado
Single point would be preferred.
Asymmetric 2 post allows for roomier door-to-post clearances.
If you are still in a quandary related to 2 post vs 4 post.... what I did to convince myself which would be better was to use duct tape and mark the location of the lift on the floor. It became apparent quickly that a 4 post lift was in the way of freely moving about in the shop.
Make sure you have enough space to move about in the shop when a vehicle is located on the lift, and the lift is lowered. My 1st shop only had about 2 feet of clearance between the post and the wall... it worked, but was a bit of a nuisance when rotating tires.
The best features are quality and safety. Buy from a reputable company that designs, builds and tests their own lifts.
What brand / type of lift are you looking at?
coljar
Belpre, Ohio
I have a two point, but I've used both and it really doesn't make any differents to me. I got a great deal on the two point Ben-Pak that I have and that is what is important to me.
