Staggering sheathing
Locker537
Massachusetts
I have been building an 8x16 shed and forgot to stagger the second row of sheathing on the rear 16 ft wall.
The shed is 2x4 16" on-center construction. The roof is 16" on-center trusses. I don't like making "mistakes" but also would like to avoid pulling the now glued and screwed sheathing down.
What would you do?
L
Locker537
Massachusetts
Leave it as it's a relatively small structure. However, an inspector would reject it — he has to. It's a shed! Don't sweat it.
That was my thought. Would it pass inspection with some compensation? For example, if blocking was added between the studs?
kbs2244
They make steel straps that you install at a 45 degree angle from the top plate to the bottom plate, across the studs, on the inside.
You don't need them, but they should make a inspector happy.
matt_i
SE Michigan
Agree on the shed = no worries. The diagonal metal strap can be a great idea if windows don't get in the way. It could be as simple as a couple pieces of 1" metal strapping (pallet banding for large/heavy stuff) that you install in an "X" pattern. The single strap is typically formed into a "T" cross-section for more buckling resistance in compression. Or, there is the 1x4 wooden cross brace that I think would be the most time consuming to install.
NUTTSGT
Northern Central Ohio
A 16' tall 8'x16' shed, damn son that's a tall shed. :headscrat
Got a picture of that ?
I wouldn't worry about it unless the inspector catches it and says something.
L
Locker537
Massachusetts
Sorry, I didn't articulate the dimensions well. It's 8'x16' and the wall height is 8'.
If I were to do it over, I'd drop the height a little bit but it does look nice in relation to the garage.
Kaizen
New England
hijacked.......along the same lines.....on a garage if I am putting up walls in individual sections with 2x at each end does nailing the 2x together make it ok that the plywood is not staggered?
Alchymist
Central PA
On a small shed I wouldn't worry about it. I have done sheds where the double 2X4 at each panel is bolted together rather than nailed/screwed, so the shed can be disassembled later.
kbs2244
I like staggered sheathing.
If the wall is too long to lift at one time I leave the overlapping spots open and the sheathing applied after it is lifted.
NUTTSGT
Nah, more like I misunderstood. I'm probably the only one that read your as 16' tall wall.
RVDan
North America
You're supposed to stagger the sheeting? Oops.
Actually my workshop is made of small pieces
jetnow1
CT.
Many commercial sheds are made with t-11 running vertical so no stagger though all
edges are nailed to the framing. You could add blocking to achieve the same thing but
I would not worry about it.
